Author Topic: Modiified Suspension Combinations for Handling and/ or drag racing  (Read 13499 times)
I got the idea from a post over on Moparts and expanded it some. I thought it might be useful  to see what others are doing in the way of making our cars handle better? Mopar owners seem to be more interested in making their cars handle now that there are more parts available than ever before.
Just copy and paste below and fill it in. Include a picture of your car at the bottom!
Entry/Update Date:
Model:
Year:
Total Weight: w/ wo  driver? :
4 corner weights if possible:  LF              RF
                                               LR              RR
Application: (Show, Daily Driver,  Autocross, road cource, Dedicated Race car, Drag ? )
Engine Package briefly:
Estimate HP: FW or RWHP
Trans:
Speed:
Gears:
Rear end  Ratio:
Rear end Type: Sure Grip, Detroit, Spool, Open , Dana 60, 8 3/4?
Front Tire Size Brand Model:
Front Rim width:
Rear tire Size Brand Model:
Rear Rim Width:
FRONT SUSPENSION
Aftermarket Front End brand:
Coil Rate:
Front Shocks:
spindle type? , stock/aftermaket? :
aftermarket front hubs? :
Front Sway bar Dia:
Torsion bar diameter:
Bump steer measurements:
REAR SUSPENSION
Aftermarket rear suspension brand:
Coil rate:
Shocks:
Rear Leaf Suspension brand/ Rate:
Shocks:
Rear Sway bar Dia:
Front Brakes:
Rotor Dia Width:
Caliper-Pistons:
Brake pad brand:
Cooling Ducts:
Rear Brakes :
Drum Size Dia Width:
Rotor Dia:
Rotor width:
Brake pad/shoe brand:
[b} Caliper- Pistons :
Master cylinder brand/aplication:
Master cylinder diameter:
Stock pedals y/n :
Power brakes y/n :
 type ? hydroboost, stock?:
Manual brakes:
Chassis
Subframe Connectors:
Torque Boxes:
Roll bar, Roll Cage:
Aftermarket stiffeners:
Comments:
1. Best above improvement:
2. Least effective above improvement
3.Future upgrades?
4. Above car handles IMO on a 1-10 ( 10 best Viper, 1 stock):
Re: Modiified Suspension Combinations for Handling and/ or drag racing
« Reply #1 on: August 03, 2012 - 08:45:56 pm »
Entry/Update Date:  August 3 2012
Model: Dodge Challenger
Year:  1970
Total Weight: w/ wo  driver? :  To be updated
                                               LR              RR
Application: Show, Daily Driver,  Autocross,
Engine Package briefly:  451" stroker, roller hyd cam, fully ported Mopar Stage 6 heads
Estimate HP: FW  540 est.
Trans:  4L60 Keisler auto OD
Speed: 4 speed auto
Gears:  3.06:1 First
            1.63:1 Second
            1.00:1 Third
            0.70:1 Fourth
Rear end  Ratio: 3:55
Rear end Type:  Dana 60 with tru trac, b-body width, 1 inch offset hangers
Front Tire Size Brand Model:  Firestone Indy 500,   235 /60 / 15
Front Rim width: 7"
Rear tire Size Brand Model:  Firestone Indy 500 , 255/60/15
Rear Rim Width: 8"
FRONT SUSPENSION
Coil Rate:
Front Shocks:  Bilstein RCD
spindle type? , stock/aftermaket? : 1973 C-Body stock spindle
aftermarket front hubs? : stock replacement rotor, drilled, slotted
Front Sway bar Dia:  Hotchkis 1 1/4" hollow stock replacemnet
Torsion bar diameter: 1.120 Firm Feel
Bump steer measurements:  .047" in 3" of upward spindle movement
REAR SUSPENSION
Coil rate:
Shocks:
Rear Leaf Suspension brand/ Rate:  Hyperco composite 225lb rate
Rear Sway bar Dia: Hotchkis tubular 13/16"
Front Brakes:  stock 1973 C-Body rotors , drilled, slotted
Rotor Dia Width: 11.750 dia. x 1 1/4" thick
Caliper-Pistons:  Stock Viper Brembo 4 piston
Brake pad brand: EBC yellowstuff
Cooling Ducts:
Rear Brakes : DrDiff  10.7 rear disc brake kit, upgrades drilled, slotted
Rotor Dia: 10.7
Rotor width:
Brake pad/shoe brand: as supplied by DrDiff?
[b} Caliper- Pistons : Ford Cobra single piston
Master cylinder diameter: 1 1/32 bore manual brakes
Stock pedals y/n : yes
Power brakes y/n : no
Manual brakes:  yes
Chassis
Subframe Connectors:  yes
Torque Boxes:  yes front and rear
Roll bar, Roll Cage:  no
Aftermarket stiffeners: US Car Tool cowl/innear fender brace
Comments:
1. Best above improvement: getting rid of bump steer
3.Future upgrades? Hydroboost brakes with 1 1/8" bore Master cylinder
4. Above car handles IMO on a 1-10 ( 10 best Viper, 1 stock):  7
« Last Edit: January 28, 2013 - 08:00:54 pm by brads70 »
Offline thedodgeboys
  • ''Normals Overrated''
    • THE DODGE BOYS
« Reply #2 on: August 03, 2012 - 09:07:15 pm »
Entry/Update Date:  8-3-12
Year:  1970
                                               LR              RR
Application: Show, Daily Driver,  Autocross, Drag Race &  General fun  :burnout:
Engine Package briefly:  Stock 6.1 Hemi
Estimate HP: FW or RWHP 420 at the wheels
Trans:  T56 Magnum 6-Speed
Speed:
Gears:
Rear end  Ratio: 4.10
Rear end Type: Sure Grip, moser housing 8 3/4?
Front Rim width:
Rear Rim Width:
FRONT SUSPENSION
Aftermarket Front End brand:  RMS alterktion coil over springs
Coil Rate:  450lba
Front Shocks:  Ajustable QA1's
spindle type? , stock/aftermaket? : Mustang II type
aftermarket front hubs? :  Wilwood
Front Sway bar Dia: .95
REAR SUSPENSION leafs
Aftermarket rear suspension brand: Hotchkis
Coil rate:
Shocks:
Rear Sway bar Dia: .75?
Front Brakes:
Rotor Dia Width:
Caliper-Pistons:
Brake pad brand:
Cooling Ducts:
Rear Brakes :
Rotor Dia:
Rotor width:
Stock pedals y/n :
Power brakes y/n :
Manual brakes:
Chassis
Torque Boxes:
Comments:
3.Future upgrades?
« Last Edit: August 03, 2012 - 09:13:28 pm by thedodgeboys »
Go Fast & Have Fun...
Offline 70Challengerrestomod
« Reply #3 on: August 06, 2012 - 04:02:00 pm »
Entry/Update Date: 8/6/12
Model: Dodge Charger
Year: 1969
                                               LR              RR
Application: (Show, Daily Driver,  Autocross, road cource, Dedicated Race car, Drag ? ) Driver
Engine Package briefly: 440, 800cfm carb, performer RPM intake, mild cam, TTI exhaust
Estimate HP: FW or RWHP: 400?
Trans: 727
Speed:
Gears:
Rear end  Ratio: 3.55
Rear end Type: Sure Grip, Detroit, Spool, Open , Dana 60, 8 3/4? 8 3/4 sure grip
Front Tire Size Brand Model: BFG  Gforce KDW2 245/40/18
Front Rim width: 8
Rear tire Size Brand Model: BFG Gforce KDW2 285/40/18
Rear Rim Width: 10
FRONT SUSPENSION
Aftermarket Front End brand: Hotchkis TVS setup
Coil Rate:
Front Shocks: Edelbrock IAS
spindle type? , stock/aftermaket? : 73 A body
Front Sway bar Dia: 1 3/8"
Torsion bar diameter: 1.03"
REAR SUSPENSION
Aftermarket rear suspension brand: Hotchkis TVS setup
Coil rate:
Shocks:
Rear Leaf Suspension brand/ Rate: Hotchkis 160lb rate
Rear Sway bar Dia: !"
Front Brakes: Wilwood
Rotor Dia Width: 10.75
Caliper-Pistons: 4 piston
Brake pad brand: Wilwood
Cooling Ducts:
Rear Brakes : Drum
Drum Size Dia Width: 11
Rotor Dia:
Rotor width:
Master cylinder brand/application: Wilwood
Master cylinder diameter: 7/8
Power brakes y/n : yes
 type ? hydroboost, stock?: Hydroboost
Manual brakes:
Chassis
Subframe Connectors: Hotchkis
Torque Boxes:
Comments:
1. Best above improvement: Hydroboost
2. Least effective above improvement:
3.Future upgrades? 13" Baer brakes front and rear, gear vendors overdrive, and aluminum heads
4. Above car handles IMO on a 1-10 ( 10 best Viper, 1 stock): 6
[/quote]
« Last Edit: August 06, 2012 - 05:41:20 pm by 70Challengerrestomod »
« Reply #4 on: August 06, 2012 - 04:15:01 pm »
Year: 1969
                                               LR              RR
Trans: 727
Speed:
Gears:
Front Rim width: 8
Rear Rim Width: 10
FRONT SUSPENSION
Coil Rate:
REAR SUSPENSION
Coil rate:
Shocks:
Cooling Ducts:
Rear Brakes : Drum
Rotor Dia:
Rotor width:
Manual brakes:
Chassis
Torque Boxes:
Comments:
Sweet ride! I love it!
« Reply #5 on: August 06, 2012 - 04:23:07 pm »
Thanks!    :cheers:    Great idea for a thread.
« Reply #6 on: August 06, 2012 - 06:17:04 pm »
Entry/Update Date:  August 6, 2012
Model: Challenger
Year: 1974
Total Weight: w/ wo  driver? : 3470
                                               LR              RR
Application: toy
Engine Package briefly: 360, stock stroke, lots compression
Estimate HP: FW or RWHP 400-425 FW
Trans: 833 4 spd
Speed: don't know yet
Gears: stock four speed
Rear end Type: Sure Grip,  8 3/4?
Front Tire Size Brand Model: 26x10x15 MT SR
Front Rim width: 8"
Rear tire Size Brand Model: 26x12x15 MT SR
Rear Rim Width: 10"
FRONT SUSPENSION
Aftermarket Front End brand: n/a
Coil Rate: n/a
Front Shocks:  Alston Varishocks single adjustable
spindle type? , stock/aftermaket? : stock FJM body
aftermarket front hubs? : n/a
Front Sway bar Dia: 1.125 solid
Torsion bar diameter: 1.22 solid
Bump steer measurements: none available yet
REAR SUSPENSION
Aftermarket rear suspension brand: n/a
Coil rate: n/a
Shocks: Alston Varishock single adjustable
Rear Leaf Suspension brand/ Rate: Mopar oval track 120# claimed, 180# observed
Rear Sway bar Dia: .95" under axle unit
Front Brakes: stock
Rotor Dia Width:  11.75x1
Caliper-Pistons: stock single pot
Brake pad brand: Raybestos metallic
Cooling Ducts:  yes
Rear Brakes : stock drums with cooling ducts
Drum Size Dia Width: 10x2.5
Rotor Dia:
Rotor width:
Brake pad/shoe brand: Raybestos
Master cylinder brand/aplication: MP aluminum bias design 60/40 split
Power brakes y/n : n/a
 no type ? hydroboost, stock?:
Manual brakes: yes
Chassis
Subframe Connectors: yes, diagonal X style
Torque Boxes: yes
Aftermarket stiffeners: n/a
Comments:
3.Future upgrades?
Have to get back to you on these, its still sitting in the garage at the moment.
« Reply #7 on: August 07, 2012 - 11:35:10 pm »
Entry/Update Date:
Model:Charger
Year:71
Total Weight: w/ wo  driver? :without 3550
                                               LR              RR
Engine Package briefly:440 ,ported heads 906 , headers , 3" TTI X pipe , 9.8:1 comp M1 single plane intake 850 carb approx 500 gross HP
Trans:A833 OD
Speed:Unlimited LOL..... theoretical top speed is 270 MPH , we all know you need double the HP to get there past approx 220 MPH
Gears:1st 3.09 , 2nd Huh, 3 rd 1:1 , 4 th .71
Rear end  Ratio:2.76
Open
Front Tire Size Brand Model: Challenger 235 60 15 S rated
Front Rim width:7 "
Rear tire Size Brand Model: Junk BFG 275 60 15 H rated
Rear Rim Width:7 "
FRONT SUSPENSION
Aftermarket Front End brand: Stock with poly bushings
Coil Rate:
Front Shocks: Gas
spindle type? , stock/aftermaket? :Stock
Front Sway bar Dia: Stock HD
Torsion bar diameter: .92
REAR SUSPENSION
Coil rate:
Shocks:Gas
Rear Leaf Suspension brand/ Rate: Stock
Shocks:
Rear Sway bar Dia: 3/4" Challenger frame hung
Front Brakes:11 3/4" Cordoba disc
Rotor Dia Width:
Caliper-Pistons: Pin type single piston
Brake pad brand:Raybestos ceramic
Cooling Ducts:no
Rear Brakes :10" drum
Rotor Dia:
Rotor width:
Brake pad/shoe brand:Raybestos semi metallic
Master cylinder brand/application: 75 Dart manual disc
Master cylinder diameter:15/16
Stock pedals y/n :yes
Power brakes y/n :
Manual brakes:yes
Chassis
Subframe Connectors: 1 x2" .125 wall  tubular
Torque Boxes:Yes
Roll bar, Roll Cage:planned but not installed
Comments:
1. Best above improvement: subframes
2. Least effective above improvement. Brkaes , useless
3. Future upgrades? Car is for sale , compelete with JFZ brake calipers
4. Above car handles IMO on a 1-10 ( 10 best Viper, 1 stock): 3  car simply will not turn , it is far easier to use the power steering of the rear tires than actually get the car to turn at all , it does stay flat in the corners , great drift car !!!
Offline jvike
  • Pro-Touring Cuda
« Reply #8 on: September 26, 2012 - 06:06:19 pm »
Entry/Update Date: 26 September 2012
Model: Plymouth Barracuda
Year: 1970
Total Weight: w/ wo  driver? : Without, 3461 lbs
4 corner weights if possible:  LF 950           RF 943
                                               LR 811             RR 757
Application: (Show, Daily Driver,  Autocross, road cource, Dedicated Race car, Drag ? ) Mostly street, occational roadrace trackday.
Engine Package briefly: 1972 340, Low comp, small valves. RPM-AirGap, Holley 650DP
Estimate HP: FW or RWHP  214 RWHP on Dynolicious app
Trans: TCI Streetfighter 727 Torqueflight
Speed: 3 speed
Gears:  Standard 727
Rear end  Ratio: 3.23:1
Rear end Type: 8-3/4 Sure Grip, 742 house
Front Tire Size Brand Model: 275/35-18 Toyo Proxis R888
Front Rim width: 9.5"
Rear tire Size Brand Model:  335/30-18 Toyo Proxis R888 (Stock wheelwells!)
Rear Rim Width: 12"
FRONT SUSPENSION
Aftermarket Front End brand: XV Motorsports Level II
Coil Rate: 350 lb/in
Front Shocks: XV Motorsports Monotube
spindle type? , stock/aftermaket? : Corvette C6
aftermarket front hubs? : Corvette C6 Mopar bolt pattern
Front Sway bar Dia:1-1/4"
REAR SUSPENSION
Aftermarket rear suspension brand: XV Motorsports Level II 3-Link
Coil rate: 225 lb/in
Rear Sway bar Dia: 1"
Front Brakes:  XV Motorsports/Stop Tech
Rotor Dia Width: 14", 1.25"
Caliper-Pistons: 6 Piston
Brake pad brand: Hawk
Cooling Ducts: No
Rear Brakes : XV Motorsports/Stop Tech
Rotor Dia: 13"
Rotor width: 1.25"
Caliper- Pistons : 2 Piston
Master cylinder brand/aplication: Mopar
Stock pedals y/n : Yes
Power brakes y/n : Yes
 type ? hydroboost, stock?: Hydraboost
Chassis
Subframe Connectors: XV Motorsports
Torque Boxes: No
Roll bar, Roll Cage: No
Aftermarket stiffeners: XV Motorports Chassis stiffening kit
Comments:
1. Best above improvement: Stiffening kit, the fundation for any suspension
2. Least effective above improvement: Parking brake
3.Future upgrades?  More power, Manuel trans, better seats
4. Above car handles IMO on a 1-10 ( 10 best Viper, 1 stock): 9, tuning and proper seats will get it there
« Reply #9 on: April 06, 2013 - 04:48:40 pm »
Nice front to rear balance!  :wow: :clapping: :2thumbs:
Offline johns cuda shop
  • 71 Cuda Pro-Touring Build
  • Machinist and Fabricator
    • Custom Machine Components
« Reply #10 on: July 12, 2013 - 08:00:26 am »
good stuff here  :popcorn:
« Reply #11 on: August 04, 2013 - 08:38:35 am »
I put my old crate on the race track scales last night and I was happy with loosing just over 200 LBS with all the aluminum on the engine and composite rear leaf springs! :2thumbs:
Entry/Update Date:  August 3 2013
Year:  1970
Total Weight: wo/ w driver? : 3611Lbs ( without driver- full tank of fuel)     3881 with driver full fuel tank
4 corner weights if possible:  LF 1021             RF 1039                                  LF 1126    RF 1061
                                           LR 771              RR 779                                   LR 873      RR 822
Speed: 4 speed auto
Gears:  3.06:1 First
            1.63:1 Second
            1.00:1 Third
            0.70:1 Fourth
Front Rim width: 7"
Rear Rim Width: 8"
FRONT SUSPENSION
Coil Rate:
spindle type? , stock/aftermaket? : 1973 C-Body stock spindle modified for e-body lower ball joints
                                                   Lower ball joints modified for Howe "quick bump" tie rods
                                                    http://www.howeracing.com/p-7449-howe-quick-bump-tie-rod-ends.aspx
aftermarket front hubs? : stock 73 C-Body replacement rotor, drilled, slotted
REAR SUSPENSION
Coil rate:
Shocks: RCD Bilsteins
Cooling Ducts:
Rotor Dia: 10.7
Rotor width:
Manual brakes:  yes
Chassis
Aftermarket stiffeners: US Car Tool cowl/inner fender brace
Comments: NEEDS BETTER TIRES when autocrossing  :eek4:!!!!!
                  Needs better rear pads when autocrossing as the fronts locks up ,the EBC pads work better
                  when they get hot. Stock rear pads do not!  :grinno:
                  I find the composite leaf springs react quicker than steel so I think adjustable shocks would be a
                  benefit
2. Least effective above improvement  Current tires
3.Future upgrades? Hydroboost brakes with 1 1/8" bore Master cylinder , adjustable shocks
« Last Edit: August 04, 2013 - 10:15:33 pm by brads70 »
Offline 73restomod
« Reply #12 on: March 29, 2014 - 09:29:47 pm »
Figured I should start this now, and update as work gets done.
Entry/Update Date: 3/29/14
Model: Challenger
Year: 1973
                                               LR              RR
Application: Autocross, Road Corse
Trans: 2002 Viper T-56
Speed: 6
Gears:
Rear end  Ratio: 3.73
Rear end Type: Spicer 8 3/4
Front Tire Size Brand Model: 245/45 ZR 18 Nitto 555
Front Rim width: 8.5
Rear tire Size Brand Model: 285/40 ZR 18 Nitto 555
Rear Rim Width: 9.5
FRONT SUSPENSION
Aftermarket Front End brand: QA1
Coil Rate: 338
Front Shocks: QA1 double adjustable
spindle type: Stock 73 big bearing spindle
Other mods : Firm Feel Fast Ratio Idler and Pitman, Sector Shaft support kit
Front Sway bar Dia: 1 1/4 tubular
Torsion bar diameter: 1.18
Bump steer measurements: going to switch to B body center-link then take measurements
REAR SUSPENSION
Aftermarket rear suspension brand: stock
Coil rate:
Shocks: QA1 Double Adjustable
Rear Leaf Suspension brand/ Rate: shooting for 175 or 180 need to read into Brads post a bit lol
Shocks:
Front Brakes: 11 7/8 cross drilled and slotted
Rotor Dia Width: 1
Brake pad brand: Raybestos Pro Grade ceramics
Cooling Ducts: also in the works
Rear Brakes : going with Dr. Diff
Rotor Dia:
Rotor width:
Master cylinder brand/aplication: Stock with Wilwood adjustable prop valve
Power brakes y/n : yes, stock vacuum assist can, plan on going to a 9 in dual diaphragm unit or hydroboost.
Chassis: Stock, going to add US Car Tool kit
Subframe Connectors: Building my own out of 2x4 Rectangular tube
Torque Boxes: Yes
Roll bar, Roll Cage: Not sure if I will install one or not.
Aftermarket stiffeners:  US Cartool
Comments: Still have lots of work to sort out,
3.Future upgrades?
Offline soundcontrol
« Reply #13 on: April 02, 2014 - 08:36:47 am »
Entry/Update Date: April 2, 2014
Model: Dodge Challenger Conv.
Year: 1970
                                               LR              RR
Application: Daily Driver
Engine Package briefly: 340, Holley, MSD Ign. TTI Shorty headers
Estimate HP: FW or RWHP: 300
Trans: 727
Speed:
Gears:
Rear end Type: 8 3/4, Dr Diff,
Front Tire Size Brand Model: 17 x 7
Front Rim width:
Rear tire Size Brand Model: 18 x 10
Rear Rim Width:
FRONT SUSPENSION
Aftermarket Front End brand: Firmfeel
Coil Rate:
spindle type? , stock/aftermaket? : Firmfeel
Front Sway bar Dia: 1-1/8"
Torsion bar diameter: 1.0"
REAR SUSPENSION
Coil rate:
Shocks:
Rear Leaf Suspension brand/ Rate: Firmfeel
Shocks: Bilstein
Rotor Dia Width: 12,88"
Caliper-Pistons: 6
Cooling Ducts:
Rear Brakes : Wilwood
Rotor Dia: 12,19
Rotor width:
Brake pad/shoe brand: Wilwood
[b} Caliper- Pistons : 4
Master cylinder brand/aplication: Wilwood
Power brakes y/n : Y  Hydratech Boost
Manual brakes:
Chassis
Subframe Connectors: US Car Tool
Torque Boxes: Stock
Aftermarket stiffeners: US Car Tool fender braces, front radiator support, K-frame kit
Comments: All of the above not installed yet.
1. Best above improvement: To be determined
2. Least effective above improvement : To be determined
3.Future upgrades? Engine, Trans. Interior, new top, paint.
4. Above car handles IMO on a 1-10 ( 10 best Viper, 1 stock): Right now -3, after upgrades hopefully great.
/ Ken
topic=108917.new#new
Offline jordan
« Reply #14 on: January 30, 2015 - 12:47:56 pm »
Entry/Update Date: 1-30-15
Model: barracuda
Year: 71
                                               LR              RR
Application: (Show, Daily Driver,  Autocross, road cource, Dedicated Race car, Drag ? )  show driver with occasional autocross
Engine Package briefly: 520 cu.in. stroker 440, 440 source heads, roller rocker,roller lifter, 6 bbl , tti headers 3 in exhaust
Estimate HP: FW or RWHP  550hp 640 ftlbs  at flywheel
Trans: GM 4l60e 4sp auto from keisler
Speed:  4
Gears:
Rear end  Ratio: 3:23
Rear end Type: Sure Grip, Detroit, Spool, Open , Dana 60, 8 3/4?  8 3/4 with eaton trutrac
Front Tire Size Brand Model:  vredestein sessanta  255/40/18
Rear tire Size Brand Model: vredestein sessanta 295/35/18
Rear Rim Width: 9.5
FRONT SUSPENSION
Aftermarket Front End brand: XV motorsports level 1 front and rear suspension system
Coil Rate:
Front Shocks: afco single adjustable
spindle type? , stock/aftermaket? :  stock type
aftermarket front hubs? : stock type
Front Sway bar Dia:  addco
Torsion bar diameter:  1.10
Bump steer measurements: ?
REAR SUSPENSION
Aftermarket rear suspension brand:  XV motorsports level 1 rear suspension system
Coil rate:
Shocks: afco singe adjustable
Rear Leaf Suspension brand/ Rate: xv level 1
Shocks:
Rear Sway bar Dia: ?
Front Brakes: PBR dual piston from late 90s mustang cobra r
Rotor Dia Width: 12
Caliper-Pistons: pbr 2 piston
Brake pad brand:  stop tech
Cooling Ducts:  none
Rear Brakes : PBR
Rotor Dia: 12"
Rotor width:
Brake pad/shoe brand:  stop tech
[b} Caliper- Pistons :  PBR single piston
Master cylinder brand/aplication:  Hydroboost
 type ? hydroboost, stock?:  hrydroboost
Manual brakes:
Chassis
Subframe Connectors:  XV motorsports floor pan contoured connectors
Torque Boxes: none
Roll bar, Roll Cage: none
Aftermarket stiffeners:   XV under radiator brace, US Cartool inner fender to firewall braces
Comments:  The car is super stiff, with a very compliant ride.  Very little body roll with excellent feedback at the steering wheel.  The brakes are super strong and predictable.  No rattles and squeaks. This cuda basically rides like a BMW 5 series with a sport package!!
I have a firm feel stage 3 steering box, PST sector shaft bearing, Tuff steering wheel, Hotchkis tubular upper control arms, boxed lower control arms, Poly bushings, Dr.Diff 1" rear leaf relocated brackets, custom bolstered seats with stock appearing skins, 3pt. seat belts, voltmeter, oil pressure and tach on standard cluster, battery relocated to the trunk
1. Best above improvement:  Chassis bracing, hydroboost, upper control arm, torsion bars, sway bars, eaton trutrac, shocks, brakes, major motor, over drive computer controlled transmission, sound deadening, large wheels
2. Least effective above improvement ?
3.Future upgrades?  Brighter modern headlights
4. Above car handles IMO on a 1-10 ( 10 best Viper, 1 stock): 8
