Chryco's Tech Shop > Interior and Gauges
gas gauge stopped working
Glennster:
I checked the wire on the sending unit, it looks OK. It's still hooked up. I looked at the fuses, old eyes make it hard to see, but I think they are OK. I installed a new 3/8" sending unit last year.
I do not have a Ralle dash.
Any ideas about what went bad?
Which fuse feeds the gauge?
THANKS!
brads70:
try giving the ground strap a wiggle.
Glennster:
I don't know what that is........
I did check the wire that hooks to the sending unit.
Jamiez:
There's a strap from the tank to the body. It provides the ground for the sending unit. Corrosion tends to be an issue with this connection. Without a good ground connection, pretty much nothing works correctly
brads70:
--- Quote from: Jamiez on July 23, 2012 - 09:22:08 PM ---There's a strap from the tank to the body. It provides the ground for the sending unit. Corrosion tends to be an issue with this connection. Without a good ground connection, pretty much nothing works correctly
--- End quote ---
:iagree: ground strap connects from the steel fuel line on the body to the steel hard line on the sending unit.
Here is one.
http://www.rosevillemoparts.com/product_info.php/p/sending-unit-ground-strap-correct-length/products_id/4118
Navigation
[0] Message Index
[#] Next page
Go to full version
