Author Topic: Turbine HVLP "Compressorless" Paint system  (Read 3978 times)
Offline buddydog
« on: May 23, 2011 - 05:02:38 pm »
Anybody in need of a stand alone HVLP turbine setup? No compressor needed. I bought this for on job and won't be needing it any more. I am letting it go for way less than retail. 500.00 shipped to your door! PM me if interested.
http://www.tptools.com/p/2994,381_Showtime-90-HVLP-Turbine-Unit-with-ProLine-Paint-Spray-Gun.html
Product description:
TP Tools SHOWTIME HVLP Turbine Paint Sprayer #TP-90PL
W/Gravity-Fed Gun, No Compressor Req. FREE Ship US-48!
SUPPORT AMERICAN WORKERS!
BUY AMERICAN-MADE PRODUCTS!
SHOWTIME 90 HVLP PAINT SYSTEM - Saves up to 50% on paint - reduces overspray up to 80%!
Sprays enamels, lacquers, urethanes, base coats, clears, primers, and epoxies - NO AIR COMPRESSOR REQUIRED!
Spray painting with a compressed-air spray gun takes a LOT of air and special water and oil filters, and produces excess overspray in your shop. By using a SHOWTIME 90 HVLP Paint System, you can eliminate those costly water and oil filters, save on paint materials, and reduce overspray, plus save your compressor for other projects because an air compressor is not required.
BEST OF ALL, the SHOWTIME 90 System will get your paint jobs done quickly and efficiently, while producing the BEST POSSIBLE FINISH on your classic car, street rod, truck, bike, tractor ... even wood finishes, right in your own garage or shop!
Car builder Bob Darney (Leetonia, OH) has completed several projects for TP Tools, and he won't use any other system. According to Bob, "The TP Tools Turbine really cuts down the overspray and saves about 50% in materials. It is definitely the best choice for automotive finishes!"
TP Tools knows HVLP!
Over 17 years experience with HVLP equipment!
SHOWTIME 90 HVLP Turbine Paint Spray System - tested and proven worldwide and made in the USA since 1993! Expect trophy-winning results! Whether you're painting single or multiple colors or pearls, this unit will get the job done quickly, efficiently, and without all the overspray of conventional spray guns.
SHOWTIME 90 does not require an air compressor! Easy to use: Simply plug turbine power unit into 115 volt outlet, add paint to hvlp gun (included), and start spraying. The turbine delivers an instant 60 cfm of air (high volume) at only 5 psi (low pressure). The high-volume air moves the paint, and the low pressure reduces overspray up to 80%. (Less overspray in the air means more paint on your vehicle!) Paint goes on smoothly with less mist and 30-50% paint savings. The turbine also warms the air which eliminates moisture and supplies dry, oil-free air to the paint gun. Warm air also helps paint dry faster, so runs and sags are eliminated.
This system quickly pays for itself! Start using this system and you will quickly realize a savings up to 50% in paint and thinner. (You can really appreciate this savings with some paints costing over $200 a gallon!) Other valuable savings are often overlooked: less dirt and dust in your paint booth and shop, extended paint filter life, extended shop fan life, cleaner floors, brighter lights, extended respirator life, cleaner environment, etc. All of this is possible because of less overspray.
TP Tools uses this system exclusively to produce Award-Winning Restorations!
Complete with 20 oz ProLine Gravity-Fed Spray Gun!
Equipped with automotive nozzle/air cap set (1.0mm nozzle, needle and .5 automotive air cap). This nozzle set will spray lacquers, enamels, base coats, urethanes, clears, primers, and epoxies. Developed by TP Tools especially for HVLP spraying. There is none finer. All material is fed into gun - nothing is wasted. Features aluminum cup assembly with gasket for positive sealing, stainless steel nozzle and needle with floating aluminum air cap, and adjustable spray from the size of a dime up to a 13" pattern.
SHOWTIME 90 HVLP Paint System (#TP-90PL) Includes:
    SHOWTIME 90 Turbine Power Unit
    TP Tools ProLine 20-oz Gravity-Fed HVLP Finish Gun (1.0mm)
    33 ft Turbine Hose
    5 ft Flex Hose with Valve
SHOWTIME 90 Turbine Power Unit Specs: Slimline case with 11" two-stage air intake filter provides dust-free air to the gun and increases motor cooling. Heavy-duty twin blade 5.7" with patented, permanently-lubricated bearings provide long life. 3/4"ID x 33 ft turbine hose with 5 ft flex hose. Includes air adjustment valve and quick disconnect. 115 volt, 12 amps. 7" rear wheels and 2" locking-swivel front wheels make unit portable. Pulls incoming air 15'' off floor for clean air and longer filter life. Produces 60 cfm @ 5 psi.16'' wide, 18'' deep, 28'' high. Turbine wt: 35 lbs. Ship wt: 61 lbs. Turbine made in USA.
Offline Cuda Cody
  • Vancouver, WA
Re: Turbine HVLP "Compressorless" Paint system
« Reply #1 on: May 23, 2011 - 05:22:58 pm »
Anyone use one of these?  I was thinking about using for work when I have to paint signs on location.  Would be easier than hauling the compressor around.
I would be interested, but if the price is only $69 less than new and with new there would be a full 2 year warranty, I think I would go with new.  Have you used yours at all?
Offline buddydog
« Reply #2 on: May 23, 2011 - 08:18:28 pm »
It has been used once but still has 18 months on the warranty. Bear in mind the shipping discount as well.  I am more than willing to negotiate a bit.
G
« Last Edit: May 23, 2011 - 08:20:28 pm by buddydog »
Offline buddydog
« Reply #3 on: May 26, 2011 - 03:45:55 pm »
Just a bump. I'll readily take 457.00 shipped.
Offline moparmaster
« Reply #4 on: June 19, 2011 - 11:32:11 am »
Still have it?  Where are you located?  $450 COD?  Thanks!
