Author Topic: 18 spline 4speed  (Read 1155 times)
Offline 71chmark
18 spline 4speed
« on: February 20, 2010 - 02:47:49 PM »
My friend has a hemi 4 speed he got from another friend about 15 years ago (said it was in a Valiant).  It has the B/E case with two shifter mounts. It worked good when they pulled it.  It looks in really good condition and it turns smothly.  He said it had the gears where you could speed shift and not use the clutch (liberty gears maybe).  He asked me how much he could get for it.
« Last Edit: February 20, 2010 - 11:59:15 PM by 71chmark »
I may be schizophrenic,
sleepychallenger
Re: 18 spline 4speed
« Reply #1 on: February 20, 2010 - 05:10:15 PM »
you sure its a 18 spline? arent the 18 splines hemi trannys? also if it was in a valiant (A body) did he change to the B and E body tail shaft?
Offline 71chmark
« Reply #2 on: February 20, 2010 - 05:35:48 PM »
I'm sure it is an 18 spline.  I said it was out of a Valiant meaning I didn't know what car it was original to.  This guy just had it in a Valiant not original.  I know Brewers quoted me $1500 for a reconditioned one about 3 years ago.  He would probably let this one go for $800.  I wonder if they are selling.
Offline 67vertman
  • Member since 9-23-2005
« Reply #3 on: February 20, 2010 - 06:15:06 PM »
I have been looking for a 18/23 spline for a few months.  They are advertised from $500 to $1400 depending on the condition.  So i think if it is an 18 spline one it should gp for $800 to $1000.
Where is it located?  because shipping could be $$$$
I may be interested, let me know if he wants to sell it.
sleepychallenger
« Reply #4 on: February 20, 2010 - 10:29:56 PM »
i saw that you said that it was from a valiant, but the reason i asked is because what works in a valiant doesnt work in a B or E body...
Offline 71chmark
« Reply #5 on: February 20, 2010 - 11:58:44 PM »
Toledo, Ohio. You can make anything fit in anything.  I went through two E Body 4 speed conversions with an early B body transmission (front shifter mount only) and a long competition plus shifter, before I even knew about the back mount ones.  Kept banging the shifter in the top of the dash but it was still fun.  Why do you say if it is an 18 spline?  I said it was didn't I?
« Last Edit: February 21, 2010 - 12:00:24 AM by 71chmark »
Alaskan_TA
« Reply #6 on: February 21, 2010 - 12:45:08 AM »
If it has a VIN stamped, what is it?
sleepychallenger
« Reply #7 on: February 21, 2010 - 09:25:35 AM »
just double checking. when you said it was from an A body, threw me for a loop.
Offline 71chmark
« Reply #8 on: February 21, 2010 - 10:35:26 AM »
I'm going over later today to get a picture.  I'll check the VIN.
