Author Topic: What is the correct carb for my 1970 Challenger?  (Read 8214 times)
Offline scf100
  • FAST LANE FOREVER!
« on: October 17, 2006 - 05:58:48 pm »
I am in the process of getting a 383 Magnum engine( mine is now a 400 in the car) and its missing the exhaust manifolds and carb.
looking in a book it show several choices Holley/Carter
my car is a auto, non a/c non Calif car so what is the correct carb and casting number?
thanks ,Stuart
1972 Barracuda 340-Yep its a barn find
Offline farmboy70
Re: What is the correct carb for my 1970 Challenger?
« Reply #1 on: October 17, 2006 - 06:29:01 pm »
If I am reading the book right it should be a Holley 4368 Exhaust manifold numbers are 2899879 and 2951865 These numbers are for R/T HP.
« Last Edit: October 17, 2006 - 06:33:07 pm by farmboy70 »
Offline Challenger6pak
« Reply #2 on: October 17, 2006 - 06:51:01 pm »
 1970 8 383
 A/T Carter AVS 4736 1468
 1970 8 383
 A/T Carter AVS 4732 1468
Is what my resources show.  I do not know why 2 are listed.
Offline farmboy70
« Reply #3 on: October 17, 2006 - 06:57:39 pm »
You may be right. I had in the remarks section those carbs for low perf and there is R/T on his picture so I went with hp. :dunno: And he doesn't have air for the 4732 carb
Offline scf100
« Reply #4 on: October 17, 2006 - 07:28:04 pm »
what book are you guys using?
yes car is an RT/SE 383 Manum
« Last Edit: October 17, 2006 - 07:35:29 pm by scf100 »
Offline farmboy70
« Reply #5 on: October 17, 2006 - 07:51:24 pm »
Galen Goviers parts and casting numbers vol 1 May 2001 is the copy I have here at home.
Offline Carlwalski
    • Carlwalski.Com
« Reply #6 on: October 18, 2006 - 04:45:38 am »
1970 8 383
 1970 8 383
 :iagree: Or possibly a Carter AVS 4734 which has an Emission Control System (E.C.S). My reference books don't show either of the above numbers as having A/C either, both are stated simply as 383 A/T 1970 Carter AVS models - weird.
Offline todd383
  • I'm a llama!
« Reply #7 on: October 18, 2006 - 06:21:49 am »
I have a 70 R/T with a 383 mag. auto. but it has a/c, and i know for sure it came with a holley carb, and the guy that had the car before me had galen decode it from the build sheet and it had a part number of  R4369A 4160 series carb. A few years back, my friend had a 383 cuda  all original, and also had the same holley.
Offline Carlwalski
    • Carlwalski.Com
« Reply #8 on: October 18, 2006 - 06:50:03 am »
Good points, wonder what determined which engines got which carbs?
My 440ci is a numbers matching car & still had the factory AVS Carter in place when I purchased it.
Here are the only possibilities for factory carburetors for 1970 383 engines:
   Year    Engine/Trans                   Make       Style                Part #
   1970    8 383 S/T                      Carter      BBD                   4725
   1970    8 383 A/T                      Carter      BBD                   4726
   1970    8 383 S/T (California)       Carter      BBD                   4727
   1970    8 383 A/T (California)       Carter      BBD                   4728
   1970    8 383 A/T (Export)          Carter      BBD                   4730
   1970    8 383 A/T                      Carter      AVS                   4732
   1970    8 383 A/T ECS                Carter      AVS                   4734
   1970    8 383 A/T                      Carter      AVS                   4736
   1970    8 383 A/T W/AC              Carter      BBD                   4894
   1970    8 383 E.C.S. A/T              Holley     4160                  4218
   1970    8 383 C.A.S. A/T A/C        Holley     4160                  4369
   1970    8 383 E.C.S. S/T              Holley     4160                  4217
   1970    8 383 C.A.S. A/T              Holley     4160                  4368
   1970    8 383 C.A.S. S/T              Holley     4160                  4367
 :thumbsup:
Offline scf100
« Reply #9 on: October 18, 2006 - 07:10:04 am »
Wow thats confusing!
looks like maybe I really have 3 that fit my situation....Carter 4726, 4732, 4736
I assume that the reg 383 engine got one of these and the 383 Magnum the other so which one could it be?
Offline todd383
  • I'm a llama!
« Reply #10 on: October 18, 2006 - 07:54:46 am »
It is confusing, but every 383 magnum i ever saw had a holley carb
Offline oldvamoparfan
  • MOPAR; The only way to go!!!!!!!
« Reply #11 on: October 18, 2006 - 08:16:56 am »
Hello Folks,  I had a new `70 Cuda 383 Commando (Same as Dodge Magnum) MT no AC which I ordered early in the year.  My brother ordered one at the same time.  We had 2 of the first ones of these cars in this area.  Both came w/ a Holley.  I dont remember the series # of the carb, but somewhere in the specs it said it was a 735CFM.  Both cars ran great, but my brothers car got terrible gas mileage, (who cares when Hi Test was about 28 cents per gal), while mine would get 20 mpg on the road if you stayed out of the 4 bl.  I am not a fan of Holley carbs, but this one was one of the best I ever had. I currently have a Holley on my Challenger w/ 360, but its off idle response is iffy, & I havent been able to tune it out.  Also, when you take it apart, it is very hard to get it back together w/o it leaking.  I think I am going to put the thermoquad back on it.  Happy motoring folks.   OVMF
'72 Challenger 360,'05 Dakota,  04 Town & Country, '82 Yamaha 650 Maxim
Offline scf100
« Last Edit: October 18, 2006 - 07:56:19 pm by scf100 »
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #13 on: October 18, 2006 - 08:53:03 pm »
It should be a Holley.
2013 Tige' RZR 343hp
Offline scf100
« Reply #14 on: October 19, 2006 - 05:59:16 am »
I know its a Holley but trying to ID the EXACT list number that it should be.....from what I have read it seems that a Holley List 4368 is correct
