Author Topic: Looking for a mopar tuff wheel adapter  (Read 54 times)
Offline brotow
  • There really is a Challenger in the backround
« on: November 20, 2020 - 09:09:51 AM »
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Re: Looking for a mopar tuff wheel adapter
« Reply #1 on: November 20, 2020 - 03:17:06 PM »
For what? Most tuff wheels will bolt directly to an E body crush can.
Offline brotow
« Reply #2 on: November 24, 2020 - 11:22:53 AM »
I like to find a tuff wheel " crush can". I have the wheel.  If I use the regular crush can the wheel will be way too close.  I always felt the regular wheels and crush can, the wheel is still to close to the driver. I was thinking of cutting down a crush can to bring the wheel further away, and maybe using a b body directional rod which is straighter(less angle). I know the set up with the tuff wheel and the shorted crush can will bring it at more or less the same distance.
« Reply #3 on: November 24, 2020 - 12:00:53 PM »
Ok so what you are looking for is something to put the steering wheel closer to the dash? There is only one crush can for an E body and while you can cut it and shorten it, you can only go so much because the wheel will be too close to the dash. You might think about moving the seat instead.
Offline brotow
« Reply #4 on: November 27, 2020 - 05:21:59 PM »
I could move the seat back then I'll need to put blocks on the pedal.   My massive height of 5'6" don't help much
« Reply #5 on: November 28, 2020 - 12:03:19 AM »
So you are actually trying to get father forward? I think cutting and shortening the crush can is your answer.
