Author Topic: PCV valve for street 440  (Read 502 times)
Offline 7Dcuda
« on: October 10, 2020 - 03:10:50 PM »
What PCV valve is everybody using for typical street build 440's?
Offline 7Dcuda
Re: PCV valve for street 440
« Reply #2 on: October 12, 2020 - 01:43:30 PM »
There are a ton of possibilities.  I'm looking for one that is known to effectively crank case ventilate (i.e. proper spring/vacuum rate) a typical 440 street build that has lower than stock vacuum levels due to cam.
Offline jimynick
« Reply #3 on: October 12, 2020 - 10:36:57 PM »
Sorry, didn't mean to muddy the waters for you. Good luck finding the perfect one.
« Reply #4 on: October 20, 2020 - 11:15:45 AM »
I think they all do exactly the same thing pretty much in the same way, its how they are packaged, how many inlet/outlets they have, how they look, etc. that set them apart from one another. It is a passive system meaning it works with engine vacuum and internal engine pressure. If your engine does not make enough vacuum to pull a PVC valve open you might want to look at an evac system where you route a line down to the exhaust.
Offline 7Dcuda
« Reply #5 on: October 20, 2020 - 05:47:03 PM »
Totally not true.  They have different internal spring tensions and different pintle sizes to work with different vacuum levels.
« Reply #6 on: October 20, 2020 - 11:19:55 PM »
I am sure that is true and since you seem to be aware of that I would then say figure out how much vacuum you are producing and get a PVC commensurate with that.
Offline jimynick
« Reply #7 on: October 20, 2020 - 11:39:00 PM »
One wonders, why a man with apparently such an intimate knowledge of the device, should ask advice in the first place. Sorry we couldn't help you and feel free to lead on.
Offline 7Dcuda
« Reply #8 on: October 21, 2020 - 11:19:02 AM »
Idiots
Offline jimynick
« Reply #9 on: October 21, 2020 - 11:48:24 PM »
Idiots
Yup, the ones who erroneously tried to help. Have a nice day.  :thumbsup:
« Reply #10 on: October 22, 2020 - 12:18:02 AM »
Idiots
Well thats pretty mature..  :screwy:
