Author Topic: 522 stroker overheating  (Read 7765 times)
Re: 522 stroker overheating
« Reply #60 on: April 15, 2020 - 11:15:04 AM »
Yes I would try a stronger cap, I just did a quick search and I believe stock they came with 16# caps.
Offline Kevin71
« Reply #61 on: April 15, 2020 - 11:53:56 AM »
I will head down today and pick up one up.  Thanks
Offline Kevin71
« Reply #62 on: April 15, 2020 - 08:19:30 PM »
I got a new cap from NAPA today with 16lb.  Well it leaks around the cap again.  So I measured the depth of the filler neck which measured 25/32" deep and the cap is 24/32" deep.  Radiator fluid is blowing by the cap.  It's not going into the overflow.  Drove it around the block and it starts blowing out.  Do they make caps with different depths?  Maybe a chevy or ford is deeper and would work.  Any suggestions.  I will call be cool tomorrow and see what they have to say.
« Reply #63 on: April 15, 2020 - 10:53:16 PM »
Excellent question, no idea. You wouldn't think they would but then again.. Well at least you know what it is.
Offline Kevin71
« Reply #64 on: April 23, 2020 - 10:09:00 AM »
Bent the tabs back on the radiator cap and that helped.  Be cool said they would replace the radiator.  So I got it our and sent back.
« Reply #65 on: April 23, 2020 - 01:58:28 PM »
Hopefully the replacement is better, you would think that those necks are built in mass and all the same depth, I think it would be odd to have one deeper than the others or normal unless this is something known to them and was a bad batch.
Offline Kevin71
« Reply #66 on: April 23, 2020 - 03:02:08 PM »
I soon as I told them the measurements I got they said they would build me a new one.
« Reply #67 on: April 23, 2020 - 11:54:39 PM »
Yeah sounds like a bad batch that they know about. Well at least you figured it out and are getting it resolved.
