Author Topic: Tan Wire In Engine Harness  (Read 625 times)
Offline DirksCuda
« on: June 03, 2018 - 01:55:58 PM »
On my 70 Cuda there is a tan wire with an eyelet on it that comes out of the bottom spot on the plug in at the bulkhead. The harness that runs thecoil and the voltage reg.there is another one that comes out by the 2 coil wires that I think is for the oil pressure gauge. Can anybody tell me where the tan one,it looks tan to me it could be faded connect. I don't see it in the manual diagrams Thanks DirkCuda
Offline 70chall440
Re: Tan Wire In Engine Harness
« Reply #1 on: June 03, 2018 - 03:55:48 PM »
if it has an eyelet on it, it is probably either for the coil  or a ground (most if not all of the grounds are black though). I dont have a diagram in front of me but you just need to trace it and see what it connects. I will look later.
Current Mopar
Past Mopars
Offline DirksCuda
« Reply #2 on: June 03, 2018 - 04:04:10 PM »
It don't go to the coil I got them hooked up. It comes right out of the harness. unless it is a ground I cant see anywhere it will connect Thanks
Offline 70chall440
« Reply #3 on: June 03, 2018 - 04:13:41 PM »
You are right, I just looked at the schematic. How long is it? Post a picture if you can. The things that take an eyelet are pretty limited so it shouldn't be that hard to figure out. How about oil pressure switch? should be grey but...
Current Mopar
Past Mopars
Offline DirksCuda
« Reply #4 on: June 03, 2018 - 09:16:28 PM »
Its about 18 inchs I'm thinking it might be the oil pressure it about that length. I'm going to posta few pic someday this week. Ive got another couple I'm not sure of Thanks for the help Dirk
