Author Topic: 73 'Cuda Fuel Line Diagram  (Read 734 times)
Offline RDF
  • The pain that greets me is the stick that beats me
« on: December 29, 2017 - 08:11:14 pm »
Does anyone have images/diagrams of how to route the fuel lines for a 73 'Cuda?  I bought new ones from Inline Tube but the old lines were pulled out a long time ago so I have nothing to go off of.  I looked at several posts on here but they either don't show what I'm looking for or the images have been removed by photobucket.
I also tried these links with no luck:
http://www.mymopar.com/index.php?pid=31
http://www.cuda-challenger.com/cc/index.php?topic=74515.msg757159#msg757159
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
Offline 73_Cuda_4_Me
Re: 73 'Cuda Fuel Line Diagram
« Reply #1 on: February 26, 2018 - 06:38:14 pm »
Hey RDF, did you ever get any response to this...???
I have my 73 up in the air, so if you want pix, just let me know what you need....
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline RDF
« Reply #2 on: March 13, 2018 - 02:49:45 pm »
Sorry for the late response but no, you're the only one.  If you happen to put it back up on the lift, snag a couple of pix for me please.  I'm baffled that no one has a diagram of this.
Bob
1973 'Cuda
My build:
Offline redo1973
« Reply #3 on: May 02, 2018 - 08:34:22 pm »
No pictures but I too used the in-line pre-bent lines - Once you unbend them from the packing.  once you get the lines through the wheel well then tend to fall into place.  I can get pictures for you but here are a couple points:
- there should be three lines correct?  One long and two smaller 1/4 inch lines (venting)
- both lines run the passenger side of the car along the outside of the frame rail.
- the main line comes off the rubber hose that connects to the tank and crosses the car along the shock shock cross-member between the cross member and the tank (need push in clips).
- there is a four hose vent separator that mounts in front of the tank
- there is a 1/4 inch vent line that comes off that vent collector
- the lines cross over the passenger frame together and travel down the frame in the wheel well (a screw in clip and spring clip) .
- The lines then cross back over the frame (there should be spring wrap at this point) to travel along the floor (push in clips at the seat plates).
- each line passes through the torsion bar cross member through separate holes.
- the main line terminates and converts to a rubber hose that connects to the fuel pump
- the vent line connects with an intermediate hose and then the short line goes up to the vapor canister
