Author Topic: Steering Column 70 Cuda  (Read 444 times)
Offline DirksCuda
« on: November 08, 2017 - 03:34:35 pm »
I'm getting things ready for when my 70 Cuda comes back from paint. I was looking at the steering column in the manual and it shows a roll pin that goes in at the coupler,but on the spline there is no hole for it to go threw. Do u just line up the coupler with the spline the pull back 13/16 then the pin rest in the groove in the spline. The car was in pieces and its the frist Mopar ive done Thanks for any help
Offline AARuFAST
  • AARuFAST
Re: Steering Column 70 Cuda
« Reply #1 on: November 08, 2017 - 08:50:16 pm »
 corrected the pin goes thru coupler and groove on steering box shaft
« Last Edit: November 08, 2017 - 08:53:13 pm by AARuFAST »
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline DirksCuda
« Reply #2 on: November 09, 2017 - 02:40:22 pm »
Thanks AARUfast .I will I know if it has to be shimmed where it connects to the dash. The manual says to save the shims but I never took it apart so I don't have any to replace them Thanks
Offline AARuFAST
  • AARuFAST
« Reply #3 on: November 09, 2017 - 08:20:11 pm »
Make sure the front wheels are aligned and the steering wheel is aligned before mounting the coupled to the steering box shaft.
1970 AAR Cuda
" I Want to Ride "
