Author Topic: Ignition indicator light  (Read 428 times)
Offline V12T
« on: October 14, 2017 - 11:32:37 am »
I hesitate to ask such a basic question, but where is the Ignition warning (on) light on the dash located. I am slowly bring the dash back to life but cannot see any sign of this. I'm in the UK so can't just check someone elses.
Offline V12T
Re: Ignition indicator light
« Reply #1 on: October 14, 2017 - 12:55:26 pm »
1970 Challenger - Standard dash
Offline 1 Wild R/T
« Reply #2 on: October 14, 2017 - 12:59:49 pm »
There is no ignition on lamp.... Why would you need one?  We have a exhaust rumble that assures you that the engine is running...
Offline GoodysGotaCuda
« Reply #3 on: October 14, 2017 - 01:52:58 pm »
Standard dash gets an E-brake, Low Oil Pressure and High Beam Indicator light. If I remember correctly..
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline V12T
« Reply #4 on: October 14, 2017 - 03:24:28 pm »
I'm not crazy then - there isn't one! I just have the three other warnings. I'm used to an ignition light to show if the alternator has failed. The volt meter does that job I suppose.
« Reply #5 on: October 14, 2017 - 03:39:37 pm »
There is no light for the charging system. The factory setup uses a [problematic] ammeter to show where the current supporting the car is coming from. It is typical to bypass the ammeter and use a voltmeter of some sort to monitor the charging system.
1976 Dodge Warlock
