Author Topic: 383 power steering pump pulley  (Read 350 times)
Offline Brace2121
« on: September 16, 2017 - 03:24:44 pm »
Hows it come off
Offline 1 Wild R/T
Re: 383 power steering pump pulley
« Reply #1 on: September 16, 2017 - 03:31:11 pm »
Special puller.... The hard part will be reinstalling the pulley... No threaded hole for an installer... So either heat or dis-assemble pump, press pulley on then re-assemble pump...
Offline Brace2121
« Reply #2 on: September 16, 2017 - 04:19:44 pm »
Thank you. I'm thinking it might be cheaper to just buy a new pulley seeing the new federal pump I bought has threads for the pulley. My guess is that puller wont be cheap and getting the pulley on sounds like a ......
Offline 1 Wild R/T
« Reply #3 on: September 16, 2017 - 05:37:54 pm »
Federal shouldn't have threads, Saginaw has threads...    Post a picture of your pump...
Offline Brace2121
« Reply #4 on: September 16, 2017 - 07:01:51 pm »
Well I guess its all foe not anyways, I opened the plastic bag off the new pump to discover that it was dropped on the cap area and damaged so now I have to see if I can send it back 3 weeks later, ugh. I am curious to what you think though cause the pumps look the same to me except the pulley shaft
Offline 1 Wild R/T
« Reply #5 on: September 16, 2017 - 09:06:45 pm »
Ahhh, by threads your referring to the internal threads to pull the pulley on with....  Not Saginaw which uses a keyed pulley & the nut threads on to retain the pulley.....  With those two check the back side to ID.... See below...
Offline 73440
« Reply #6 on: September 17, 2017 - 01:06:48 am »
I bought a Federal pump , confirmed with 1 Wild R/T back photo, casting 2537955 , from Napa to replace my leaking pump.
My old federal is the same as the red one in your photo.
Due to more pulleys offered for the Saginaw , I will probably go with the Saginaw with all new pulley setup for the alt, damper , ac and ps.
https://www.cvfracing.com/Chrysler-Big-Block-A-C-System-p/440-ac-system.htm
This pump is re manufactured  and never installed, if you are interested in it , I can ship to you, I do not have a pulley.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 386,085 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Brace2121
« Reply #7 on: September 17, 2017 - 03:47:23 pm »
Dam, its a TRW pump thats in it. I didnt even realise there was 3 different pumps.
If I want use the same mountng bracket etc do I need to buy another trw or can I go with a federal again providing I can return the damaged one they sent me.
Some how I want get rid of the pulley I have now because I have no idea how Im going to press it on.
Offline Brace2121
« Reply #8 on: September 17, 2017 - 03:50:22 pm »
Thanks but i just realized I have a TRW, so now Im not sure what im doing. I'll let you know
Offline Brace2121
« Reply #9 on: September 18, 2017 - 06:38:08 pm »
Does anyone know if the mounting bracket for the trw and federal pump is the same?
I
Offline 1 Wild R/T
« Reply #10 on: September 18, 2017 - 07:51:01 pm »
I
definitely not...
Offline Brace2121
« Reply #11 on: September 19, 2017 - 01:34:02 pm »
Thank you. Would you happen to know if a reservior seal/o-ring will fit on both the federal and trw pump? The front looks similar in pics but I cant find any dimensions.
I think someone actually put a trw pump on with federal brackets because now that im looking closely the belt is was out of alignment, actually amazing it stays on....
