Author Topic: oil filter gaskets  (Read 190 times)
Offline brotow
  • There really is a Challenger in the backround
oil filter gaskets
« on: August 29, 2017 - 06:15:56 am »
I have new oil filter adapter gaskets I am going to install, however I'm not sure of the way the small cork gasket goes. I think the small fiber gasket goes under the bolt. does the cork gasket go under the adapter?
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv.
Offline 73_Cuda_4_Me
Re: oil filter gaskets
« Reply #1 on: August 29, 2017 - 07:39:49 am »
 :2thumbs:
Yup!
1973 Plymouth Cuda BS23H3B567783
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline JayBee
« Reply #2 on: August 29, 2017 - 08:32:33 am »
Here's a couple pictures from my 1970 / 71 Parts Catalogue. It doesn't show anything under the adapter.  :dunno:   :2cents:
John
1970 Barracuda convertible
2000 Toyota Avalon
Offline JayBee
« Reply #3 on: August 29, 2017 - 08:37:20 am »
Here's one I found on the web. It doesn't mention cork and fiber, rather they're called nylon and copper.
John
2000 Toyota Avalon
« Reply #4 on: August 29, 2017 - 12:26:53 pm »
Most replacement 3-piece gasket kits for the 90-degree adapter have the fiber and cork gaskets... the fiber one (thin) goes on the head of the mounting bolt, and the cork one (thick) goes on the bolt between the 90-degree adapter and the block. Large diameter gasket goes on block (make sure old one is removed before putting new one on).
Make sure to torque mounting bolt to spec, or expect leaks.
R11 V6X EN2
Offline brotow
« Reply #5 on: August 29, 2017 - 01:06:49 pm »
Anyone know the torque spec?
« Reply #6 on: August 29, 2017 - 01:16:39 pm »
See bottom of picture of previous post... 50 ft/lb max
R11 V6X EN2
