Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Exhaust Systems
(Moderator:
Chryco Psycho
Broken exhaust manifold stud
« previous
next »
Print
Pages: [
1
Author
Topic: Broken exhaust manifold stud (Read 1236 times)
73440
Sr. Member
on:
May 06, 2017 - 02:53:03 pm »
Took a drive to Smileys Racing to buy 5 gallons of VP 110 leaded. Adjusted the idle, checked timing , it's at 12 btdc , then tried to reduce exhaust manifold leak and decided to snap one of the studs.
Still has the original turquoise paint on the bolt.
Logged
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 408,375 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
xtopfuel
Jr. Member
Re: Broken exhaust manifold stud
Reply #1 on:
May 06, 2017 - 04:02:15 pm »
Ugh that sucks
Logged
73440
Sr. Member
Reply #2 on:
May 06, 2017 - 05:20:18 pm »
It turned very easy, so it was probably going to let go soon.
Now it matches the starter bolt threads in the bell housing that are stripped.
40 year old engine will do that.
Logged
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
xtopfuel
Jr. Member
Reply #3 on:
May 06, 2017 - 11:25:53 pm »
True
Logged
mopar jack
Full Member
Reply #4 on:
May 07, 2017 - 09:43:37 am »
I have had that happen on the drivers side rear bolt, just broke off with no torque.
Logged
73440
Sr. Member
Reply #5 on:
May 07, 2017 - 03:54:11 pm »
I recently replaced the header with the exhaust manifold and maybe it's possible that with the heating and the cooling and the different expansion rates of cast iron and steel tubing the stud stretched it a little bit because it was fine a month or so ago when I last checked .
This stud was drivers side second from front.
Logged
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
67vertman
Sr. Resident
Member since 9-23-2005
Reply #6 on:
May 08, 2017 - 01:35:11 pm »
Sorry hear that.
Hopefully it is not flush to the head and you can get it out easily .
Logged
Current ride - 1970 Barracuda 440-6 4 sp Dana 60 (4:10)
73440
Sr. Member
Reply #7 on:
May 08, 2017 - 02:19:39 pm »
Probably flush, it snapped right at the start of the threads.
Logged
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
340-FOUR- BARRELL
Jr. Member
Reply #8 on:
July 20, 2017 - 12:13:18 am »
Been there several times. Used the wick method with paraffin to remove snapped exhaust manifold bolts.
Logged
1 Wild R/T
Resident
Reply #9 on:
July 20, 2017 - 01:17:50 am »
Weld a nut onto it & unscrew...
Logged
JS27N0B 70 Challenger R/T Convertible FJ5 Sublime, Show Poodle w/90,000 miles since resto
WS27L8G 68 Coronet R/T Convertible PP1 Bright Red, Project
5H21C 65 Falcon 2 dr Wagon... Dog Hauler...
73440
Sr. Member
Reply #10 on:
July 20, 2017 - 06:56:44 am »
Thanks, I need to do some work on this , will try the parrafin first and have the welder ready to go also.
Thinking of getting new set of studs installed all around while doing this repair.
Logged
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Exhaust Systems
(Moderator:
Chryco Psycho
