Author Topic: 73 Road Race Cuda  (Read 155152 times)
Re: 73 Road Race Cuda
« Reply #1065 on: November 17, 2018 - 09:56:23 PM »
Well I've got almost all of the interior trim in, still have to install the visors. I had it running tonight, seems that my leak is taken care of so now i am draining the cooling system to add anti freeze.
While it was running I noticed an issue, the alternator is only producing 11.9-12V; it is brand new 120A for of a 91 Dakota. I did have to replace the pulley as it came with on for a serpentine belt, I wonder if I am not spinning it fast enough?
Waiting on the seat guy (he has had my seats since June 9th), he is supposed to be bringing my back seat for a test fit... we will see; he also owes me some seat belts...
« Reply #1066 on: November 20, 2018 - 02:06:59 PM »
Got the back part of the back seat, also installed the sun visors so that is done. Still have to tidy up the wiring on the interior.
Offline YellowThumper
  • I left the snow for this?
« Reply #1067 on: November 21, 2018 - 01:16:30 PM »
Nice
« Reply #1068 on: November 21, 2018 - 01:21:58 PM »
got to love leather  :bigsmile: now I just need the rest of them...
« Reply #1069 on: November 22, 2018 - 12:10:34 AM »
Got to work on the alternator today, I had to replace the pulley. I bought a new one from JEGS which is much smaller than the one I was using. The one I had on the alternator was a Canton racing product but it was an under drive pulley. The new pulley fit the shaft of the alternator however the shaft was not long enough to get the nut on. Fortunately I have been working on my machining skills and was able to machine it down a little to get the nut on.
The next project is to make a threaded spacer; basically this will thread into the head and then the bolt holding the bottom of the alternator will thread into it. The reason for this is that I have been using a long grade 8 bolt however it is very difficult to get out to remove the alternator because the bolt hits the electric fans on the radiator. I made one but I don't like it so I will make another.
For anyone interested I have a HF 3 in 1 mil/drill/lathe that I bought probably in 2000 but really never used it. I am not a machinist by any stretch by I am learning and making chips  :bigsmile: It is so nice to be able to make your own parts.
Offline 73440
« Reply #1070 on: November 22, 2018 - 10:11:24 AM »
Always neat to make a part yourself!
Been looking at those type  of 3 in 1 also.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #1071 on: November 22, 2018 - 11:25:42 AM »
I bought it at a time when I really didn't know anything about it or machining for that matter. I did ask some people I trusted and anyone who had machining experience advised not to get a combo machine, rather to get a dedicated Mill and a dedicated lathe; problem of course was cost seconded only by space. At the time I was working out of a 2 car garage so in my mind the 3 in 1 machine was a better deal. Well, over the years and as I gained more knowledge I began to understand why they said what they did; the combo machines are very limited in what they can do specifically due to size. As it relates to the HF unit itself, it is pretty sloppy in terms of accuracy which for a long time really deterred me from using it; it wouldn't cut straight, would jump around etc. Well eventually I my neighbor who has an actual machine shop come over and look at it; he explained how to adjust it to remove some of the movement and after some discussed I determined that it could be useful for what I am doing (car and gun work).
I don't know your background so if what I write after this is something you are knowledgeable in I apologize, but I figured I would write it up in case anyone is interested.
The biggest issue with these machines (or really any for that matter) is tooling. The combination mill vise/lathe tool post is a pain to use and not very good at either function (better at holding the lathe tool post than as a mill vise). Therefore as I began to research my options I began to purchase tooling; got a quick change lathe bit tool post, new 3" mill vise, hold down kits, 123 blocks, etc. These all made HUGE differences in what I can do and to what quality I can do it. There is an endless list of tooling you can obtain, much of what you don't need (but will want...).
My best advise reference a mill and/or lathe is if you can afford it and intend to become a machinist (even a hobby machinist) get a dedicated Mill and a dedicated lathe. The reason is that they are so much more powerful and capable than a small machine. If however this isnt an option due to cost or power requirements (most Mills require 3 phase 220) then look at the small 3 in 1 machines. Look at Smithy to begin with, this is their forte and they make some really nice machines but cost around $2500 - $5000 depending on model. if this is out of your price range, then look at the HF units but know that you are going to have to do some work to make it usable.
On the HF unit, you will need to really clean it; I don't mean wipe it down I mean taking a lot of it apart and cleaning it thoroughly. I used some 50% gas/oil solution (like you would use for a chainsaw) and a red Scotchbrite pad and 000 steel wool. Then you need to adjust as much of the slop out of it that you can which can take some time. You need to mount it some place solid and spend some time leveling it up. After that, you need to look at obtaining some additional tooling for it which can be frustrating and confusing at times. You have to know what size machine you have as in the machinist world they use a lot of terms that are not real familiar. The HF unit I have is basically a 12-20 machine so when you are looking for tooling you need to know this. You also need to know what spindle size you have as well as tail stock size; mine is a Morse 3 taper on the spindle and a Morse 2 on the tail stock (aka MT3 and MT2 respectively).
Keeping in mind that I am not a machinist by trade or training, but I have been around it for a long time and have a basic understanding of it. Additionally I have quite a few very good friends who are machinists that I can easily ask questions of. That said, I have found the internet to be invaluable as there are a lot of people who use the small machines for a variety of things. As you may know or will see there are dedicated websites for the use of small machines and tooling is readily available especially on Amazon. Lastly, YouTube is your friend and will show you how to do about anything, I use it frequently.
The HF unit gets a pretty bad rap but to be honest, for a hobbyist who is making relatively minor (but essential) parts, it will deliver if you take the time to set it up and work within its limitations. My biggest problem is understanding the measurements and what the various increments on the machine yield on the part. I really need to spend some time adapting a DRD to it (digital readout) as the dials on the machine are not super accurate.
Sorry for the long post but I figured someone might be interested in the information. Long story short, I really like using the unit and have made a number of things with it recently. If you fall into one on sale or used one cheap, its worth getting, but know you are going to have to spend many times the initial cost to get it really productive due to tooling, but this is the same with any machine you would get unless you fall into someone closing a machine shop and willing to give it all to you.
Offline 73440
« Reply #1072 on: November 22, 2018 - 01:21:58 PM »
I agree with what you wrote about the limitations , the machine and mine, and the work to make them decent.
Would love separate but at first will probably try the combo.
Although looking at used and vintage machines also.
The vintage machines is what I would really like to get.
Went into a shop which we were thinking of buying the bldg not the business and they had some cool old and new tooling machines .
Have a CNC shop at the end of the street from me if I really need something.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #1073 on: November 22, 2018 - 01:42:37 PM »
Sounds like we have a lot in common  :bigsmile: my neighbor has 2 CNC mills, a new (used but new to him) CNC lathe as well as a conventional bridgeport and lathe. I am working a deal to obtain an old bridgeport and lathe but its a long shot but we will see.
Offline 73440
« Reply #1074 on: November 23, 2018 - 12:40:34 PM »
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #1075 on: November 23, 2018 - 01:14:09 PM »
Yeah thats a great explanation.
« Reply #1076 on: November 26, 2018 - 12:16:33 AM »
30 years in the machining biz for me.
Specifically plastic injection moldmaker.
I agree dedicated is better. And yes I have mine at home also. Lol.
However the 3 in 1 can be very useful for the hobbyist. Start small learn as you go and learn is bigger and stronger is in your cards. With dedicated machines most run on 220v 3 phase. Wiring becomes an issue with added expense. They are heavy and will require machine movers. Or like me a vivid
Imagination bordering on dangerous...
Also had to move it across my front lawn without damaging anything. By myself.
In short. Making parts for yourself is awsome.
Mike.
« Reply #1077 on: November 26, 2018 - 12:25:11 AM »
From one Mike to another...  :bigsmile:
Moving the equipment isn't an issue, I have a Bob Cat. Powering the equipment isnt a problem either as I have a rotary phase converter already in the shop for my vertical Mil/Drill.
I agree about the 3 in 1, I am learning new things every time I use it. I am definitely starting small, it took me like 3 days to make one small part or better said remake it enough times to get it done.
I know all about "imagination bordering on dangerous", been there far too many times myself.
« Reply #1078 on: November 27, 2018 - 01:45:51 AM »
When you feel brave I will explain how to turn a ball with the mill portion...
Sooo many things that once you know them they are actually simple.
If I had not already stated. 35 yrs machining for me.
« Reply #1079 on: November 27, 2018 - 11:58:18 AM »
Well I am always brave but I don't think I have the experience or skill yet to try that. You did mention a long history in machining but its worth mentioning again. I am really just beginning for all intents and purposes. I have been around machining for a long time and have experience in dimensions, prints and drawings but I am only beginning actually doing the machining myself. I am having fun with it and learn something every time I get near the machine. YouTube has been my friend for sure, also my neighbor has been exceptionally helpful as he has a full machine shop.
