Author Topic: Penski61 73 challenger  (Read 3107 times)
Offline penski61
« on: September 04, 2017 - 08:19:45 pm »
Well figured I'd start a build thread but not sure if it goes here or resto mod . Plan is to put in a built 6.4 hemi with 6 speed, gerst coilover front suspension and custom 4 link rear with double adjustable coilovers and built Dana 60.
Here is what I've got so far , took the 60 out of the duster I was building , got the frame plated and got the lower coilover mounts on the axle . Need to cut the brackets off that were for the duster then once the frame mounts show up I can get those welded in
« Last Edit: September 10, 2017 - 09:49:02 am by penski61 »
Offline Beekeeper
Re: Penski61 73 challenger
« Reply #1 on: September 04, 2017 - 08:39:07 pm »
This looks interesting. Can't wait to watch your progress.
Offline 1 Wild R/T
« Reply #2 on: September 04, 2017 - 09:16:37 pm »
I hope you have something more substantial then the stock shock crossmember in mind to connect your coilovers to....
Offline penski61
« Reply #3 on: September 04, 2017 - 09:29:18 pm »
yeah ill probably have to cut it out and make a tube cross member or figure out a good way to re-enforce since it bends by hand   but for now its good for mock up
« Last Edit: September 04, 2017 - 09:47:37 pm by penski61 »
Offline penski61
« Reply #4 on: September 06, 2017 - 11:36:19 pm »
got the frame mount brackets delivered today  but are not going to work like I planned , Ill have to shorten the upper links in order to clear the floor at full bump by doing this it doesn't allow the brackets to line up correctly from frame side to axle side .plan is build a sort of sub frame if you will that the upper links will attach to then that subframe will have supports that tie back into the upper coilover mounts . it will be more work than cutting the upper brackets off the axle and starting over but should turn out decent , hoping to start on all that this weekend . already got the original shock mount cross member cut out but will have to pull the axle for more working room
« Last Edit: September 06, 2017 - 11:38:50 pm by penski61 »
Offline Beekeeper
« Reply #5 on: September 07, 2017 - 12:15:20 am »
 :popcorn:
« Reply #6 on: September 07, 2017 - 12:21:47 pm »
I did the same thing for my cuda; I removed the cross member and cut out and rebuilt the area where the shock actually bolts in. I also added a number of gussets across the member, also added supports and gussets where the member meets the frame.
Offline penski61
« Reply #7 on: September 07, 2017 - 10:23:40 pm »
more progress , shot of the shock cross member cut out and new cross member for the upper link mounts . the new cross member for the coilover will tie into this cross member for even more support
« Last Edit: September 10, 2017 - 09:49:34 am by penski61 »
« Reply #8 on: September 07, 2017 - 11:20:54 pm »
 :wow:
Offline Beekeeper
« Reply #9 on: September 07, 2017 - 11:31:25 pm »
Very nice. Looking forward to more pics as you move along.
Offline penski61
« Reply #10 on: September 09, 2017 - 09:21:51 pm »
got more done today  , the hoops legs go thru both sides of the frame and are plated on the inside of the frame .tomorrow ill see if I can make the upper coilover mounts off the hoops
« Last Edit: September 09, 2017 - 09:37:08 pm by penski61 »
Offline Beekeeper
« Reply #11 on: September 09, 2017 - 10:19:06 pm »
I know very little about these suspension upgrades so not sure what is normal or not but I really admire metal fabrication stuff like this. Love the pics! Keep em coming please.
« Reply #12 on: September 09, 2017 - 10:19:50 pm »
Nice work for sure.
Offline penski61
« Reply #13 on: September 17, 2017 - 11:42:42 am »
Just about wrapped up with the 4 link
Offline Katfish
  • 70 Challenger
« Reply #14 on: September 17, 2017 - 11:57:44 am »
 Very nice!  Looking forward to your updates, Gen III Hemi is my long term goal
