Author Topic: Really weird turn signal issue  (Read 1119 times)
Offline marcus
« on: August 11, 2017 - 08:21:33 pm »
Just replaced the turn signal switch assembly and the problem is still there. It's a weird one.
Only happens at dark when all lights are on.
After about 15-20 minutes of driving the left turn signal indicator starts to dimly turn on/flicker.
Flashing the left turn signal indicator makes it go away.
What could be causing an issue like this?
Here is a video of it happening
https://youtu.be/7tdrqJdRfhA
Re: Really weird turn signal issue
« Reply #1 on: August 11, 2017 - 08:58:14 pm »
Never heard of such but most issues of this nature are due to poor grounds...
My first instinct is to suspect the flasher .. power has to discharge through the flasher if I understand the system
Online GoodysGotaCuda
« Reply #2 on: August 11, 2017 - 10:14:02 pm »
I'd have to investigate the ground circuits as well. I wouldn't be surprised if a poor chassis ground on a light is somehow backfeeding through the other element to find ground at the fender indicator [or something like that].
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline TelisSE440
« Reply #3 on: August 12, 2017 - 01:24:20 am »
 :iagree: Check the left aluminum housing of the front turn amber light, clean it thouroughly from rust dirt etc and tight it firmly on to the chassis, check by using a light tester grounding the grey aluminum case. If this case doesn't ground to the chassis or is rusted/dirty then a current feedback occurs targeting your turn signal indicators. Hope i helped
Offline garity
  • 74 Challenger
« Reply #4 on: August 12, 2017 - 02:10:37 am »
The flasher circuit shares a fuse with the radio and the neutral safety switch. Maybe try disconnecting the radio power and then the connector to the neutral safety switch/backup light near the wiper motor area under the front hood. The exhaust manifold can burn the insulation on the wires to the neutral safety switch harness if it is too close to it. Something to try anyways.
Offline marcus
« Reply #5 on: August 12, 2017 - 01:35:06 pm »
Ahhhhhhhhhhh!! This explains things! I have noticed during the day that the left front fender turn signal indicator sometimes does not flash while the others do. So I never put 2 and 2 together.   :eek4:
What your saying makes perfect sense. During the day the indicator works intermittently (due to poor grounding) and during the night I can see current feedback going though it (due to the same poor grounding).   I will inspect and clean all the grounds today. Thanks for the tips!
Offline DAYLEY/CHALLENGER
« Reply #6 on: August 12, 2017 - 10:38:01 pm »
By all means check the grounds...  And the video, it took me 15 minutes to get back to the thread.  Just can't watch just one! :bigsmile:
Dave or David
Offline marcus
« Reply #7 on: August 13, 2017 - 02:11:18 am »
Fixed! Video details here-
https://youtu.be/jqOyQpDVodc
Thanks again!
Offline TelisSE440
« Reply #8 on: August 14, 2017 - 09:18:43 am »
Thanks again!
Glad you sorted it out!  :thumbsup:
