Author Topic: Attn: Final parts list! Updated 6/26/14  (Read 14049 times)
Offline DMZ73
    • http://www.pbase.com/dmz73/
Re: Attn: Final parts list!
« Reply #30 on: June 17, 2014 - 11:30:14 pm »
Welcome Damon!! It was great to meet you! Loved wrenching with you on Saturday. I'm sorry I didn't get a lot of time to learn from you on the trans assembly. I would really like to gain more understanding of that puzzle someday.
I'll add the trans cover to the list.
Cooler and bracket would be great!
dmz73
Offline DMZ73
« Reply #31 on: June 17, 2014 - 11:36:54 pm »
Dan, I remember we needed a water pump housing bolt kit or I'd've put it on last Saturday and do you have bolts for the intake? A distributor holdown and bolt? Was there no coil wire in that dusty old Accell wire kit? Wiring separators? Throttle cable/return spring and spring bracket? Just some wee pieces I thought about. Damon, good to see you on here, buddy! Regards,Ian
Ian,
I have a dizzy hold down bracket and I think I have the bolt.
No throttle return springs
No throttle bracket
Need intake manifold bolts
Need water pump bolts
No trans kickdown rods- easiest: we are going with the Lokar kit.
Yes, still missing a coil wire! Argh!
Dan
dmz73
Offline blown motor
« Reply #32 on: June 18, 2014 - 09:23:48 am »
Dan, we are using the blaster 2 coil correct? If you can get me a length on that wire I might be able to make on from leftover wire and boots I have from putting new wires on mine. I could also tap into a friend's leftovers. It would be bright orange. I also have a shabby blue coil wire that we could put a new end on if it's long enough. It's currently HEI at the coil.
Offline BIGSHCLUNK
« Reply #33 on: June 19, 2014 - 12:50:36 pm »
Milodon dipstick and ballast resistor sent today.  :thumbsup:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #34 on: June 19, 2014 - 06:21:15 pm »
Dan,
 The distributor and voltage regulator shipped today to Andy's house.
Offline p-zero
« Reply #35 on: June 19, 2014 - 08:09:44 pm »
 Hey Dan do you update the original post with the parts you still need? (This is Pete, Andy's neighbor.)
 I can get a bunch of parts, and rather quickly at that, so let me know.
« Reply #36 on: June 19, 2014 - 08:53:37 pm »
Still need the Oil Pump ?
Offline jimynick
« Reply #37 on: June 19, 2014 - 10:08:08 pm »
I've sent the intake bolts and return spring/bracket kit to Cathy. Summit said they'd ship tonight and arrive either Saturday or Monday; so we can stroke those off the list as well.  :thumbsup:
Offline DMZ73
« Reply #38 on: June 19, 2014 - 10:09:40 pm »
Chryco- yes we do still need to oil pump
dmz73
Offline DMZ73
« Reply #39 on: June 19, 2014 - 10:22:43 pm »
I need that brake booster Pin and cotter pin for Andy's car. I can't find it in his box o goodies
Dan
dmz73
« Reply #40 on: June 19, 2014 - 11:43:22 pm »
Oil pump should be there shortly
 let me know it arrived Please
The brake linkage is a tough piece to find
« Reply #41 on: June 20, 2014 - 12:11:46 am »
Ian,
No throttle bracket
Dan
dmz73
Would these items solve the kickdown, bracket & return spring issues?
http://www.jegs.com/i/Lokar/625/KD-2727HT/10002/-1
http://www.jegs.com/i/Lokar/625/SRK-4000/10002/-1
directions  http://www.lokar.com/downloads/pdf-instructions/chrysler-kickdown.pdf
I'll send you the $ for you to order....PM me instructions
Offline p-zero
« Reply #42 on: June 20, 2014 - 12:36:05 am »
I can check into the
Dan
dmz73
 I can check on those pins tomorrow. I have an assortment of cotter pins.
Offline blown motor
« Reply #43 on: June 20, 2014 - 09:36:10 am »
Gas cap to be shipped today.
Offline DMZ73
« Reply #44 on: June 20, 2014 - 10:55:12 am »
I can check into the  I can check on those pins tomorrow. I have an assortment of cotter pins.
Pete:
First: welcome!!
Second: I will need the shaft that works as  the brake booster linkage pivot. That part has the hole for the cotter pin.
Please take another look at the list. I update the list every time someone donates a part. It changes constantly.
I could probably use your mechanical skills more than anything when we put her together.
We still need wheel spacers
Some longer wheel studs,
A Nippon denso alternator pigtail
A mini starter
And some other bits and pieces.
Dan
dmz73
« Last Edit: June 20, 2014 - 11:09:45 am by DMZ73 »
