Author Topic: Radiator Fan  (Read 1249 times)
Offline 69bcuda
Re: Radiator Fan
« Reply #15 on: August 05, 2017 - 10:23:17 am »
" because the shroud or engine position isn't "centered". "
Mopar drivelines are offset. Some reference..........
http://ttiexhaust.com/Footnotes/FN_39.htm
Offline 72and86
Re: Radiator Fan
« Reply #16 on: August 05, 2017 - 11:51:54 am »
Thanks, good to know
Offline 72and86
Re: Radiator Fan
« Reply #17 on: August 06, 2017 - 12:46:18 am »
Im taking the shroud off and trying the 7 blade fan directly and see how it goes.
Offline 72and86
Re: Radiator Fan
« Reply #18 on: August 07, 2017 - 10:44:44 am »
So I took off the shroud (because it wouldn't center w/ the new fan). I mounted the new (old) 7 blade clutch fan without the shroud, and there's a small slight improvment with cooling. It runs just a hair below the center mark on the temp gauge when the car is moving and a little above the center line when at idle. My idle is approx 700 rpm.
I guess this is ok?
Offline 73_Cuda_4_Me
Re: Radiator Fan
« Reply #19 on: August 07, 2017 - 07:49:03 pm »
What was the ambient temperature outside when you ran/idled it? Mine will run 95 percent of the time below half-way on gauge... usually ambient is less than 90 degrees outside (I don't have A/C, so rarely drive it when it's that hot outside!)... once in a while idling in park will get half-way or a smidge over...
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline 72and86
Re: Radiator Fan
« Reply #20 on: August 08, 2017 - 12:40:52 am »
With new fan it was about 80 out.
Re: Radiator Fan
« Reply #21 on: August 08, 2017 - 07:56:04 am »
 :2thumbs:
R11 V6X EN2
