Hello all. I need a little help with an electrical issue I'm having with my 70 Cuda. The battery on the car was going bad, so I hooked a charger up to it, and put a trickle charge on it over night. The next morning, I go to start the car, the interior dome lights are working, but when I turn the key...Nothing. Car wont even attempt to roll over even though the lights are working on the dash. I figure the battery is just bad, so I just replace it with a new one. After installing the new battery, the car fires right and everything works perfectly. This morning, I get in the car to take it work, turn the key and again, nothing. I pop the hood and check the terminals. Tighten one that was a little loose, and then the car fires right up when I turn the key. I turn the car back off again, and then immediately try to turn it back on, and the again...Nothing. Any ideas of what could be causing this? Seemed the car was working fine until I put the trickle charge on it. Thanks in advance.
