Author Topic: Hemi Carter AFB Carb connection to Distributor Advance  (Read 274 times)
Offline MopSquad
« on: August 16, 2017 - 12:55:47 am »
Pulled my rear Carb off the 426 hemi to rebuild possibly. It only has a 1000 miles on it but the first 650 were over a 5 year period. It runs a bit rough off idle.  On removing the Carb, I notice that the hose to the distributor advance was laying unconnected between the front and rear carbs.  The rear Carb has a nipple cover on the front port.  Shouldn't the distributor advance hose be connected?
TIA,
Steve K.
« Last Edit: August 16, 2017 - 11:22:52 am by MopSquad »
Offline MopSquad
Re: Hemi Carter AFB Carb connection to Distributor Advance
« Reply #1 on: August 16, 2017 - 06:46:48 pm »
Talking to Scott Smith the carb expert.  The nipple in the front of that carb is the attachment point for the distributor vac advance hose.
Offline cudabob496
« Reply #2 on: August 16, 2017 - 07:39:40 pm »
well, yes, the hose should be connected, if you want vacuum advance to work?
Offline MopSquad
« Reply #3 on: August 17, 2017 - 02:41:17 am »
LOL.  Yes, thought that there was possibly some odd lockout preference that some hemi owners did on the dizzy.
