Author Topic: 383 engine temperature  (Read 786 times)
Offline cudabob496
Re: 383 engine temperature
« Reply #15 on: August 17, 2017 - 08:49:13 pm »
if gets hot at high speed, could be:
engine coolant needs flushing
lower rad hose is collapsing
radiator not completely full (have a recovery bottle, not
an overflow bottle)
engine compartment too tight, which limits air through radiator
Aluminum radiators are the way to go.
I have a front splitter which makes more air flow into radiator
Have a separate tranny cooler, and bypass the radiator.
Use Purple Ice coolant treatment from Royal Purple
Make sure total timing does not exceed 36 BTDC
Use higher octane gas
Make sure have a fan shroud
