Author Topic: 440+ 6 Temperature spike when stopped...even for a short time.  (Read 5326 times)
Offline Tazinhawaii
Re: 440+ 6 Temperature spike when stopped...even for a short time.
« Reply #30 on: June 21, 2017 - 09:14:47 am »
Air bubble in system or Tstat is not opening.  I know you said its new, but...........
 :iagree:  I had the exact same thing happening to me a few months ago when I changed out the radiator.  Everytime I would stop at a light the temp would scream up and come right back down when I started going again.  Did it for a day or two and then went away.  I attributed it to an air bubble in the heads (also changed heads).  Ran cool after that until my unrelated current issues happened.
Derrick
1971 Cuda 440 six pack.  Original TX9 Black on Black.  Located in southern NH.
Offline Travis Blake
« Reply #31 on: June 21, 2017 - 10:18:51 am »
Derrick
With the top hose being pliable, I'm wondering if I do have air in there. Before we changed it, I remember the top hose being firm with the engine is hot. Can anyone confirm if it should be pliable or firm, and what that indicates?
1974 Dodge Challenger  - 440 Six Pack
2015 Jeep Wrangler Unlimited - Willy's Edition
Offline cudabob496
« Reply #32 on: June 21, 2017 - 12:52:15 pm »
Tsat upside down?
Offline 73440
« Reply #33 on: June 21, 2017 - 02:15:04 pm »
Hose should be firm after thermstat opens,
Almost like the water pump is not turnng inside the housing.
Had a concrete pump hose clog due to a flap of the inside rubber of the hose folded down against the flow and plugged the line.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 396,936 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline polarbear123
« Reply #34 on: June 21, 2017 - 02:26:09 pm »
I had the same problem when I sat at red lights. I ended up getting a Milodon high volume water pump.
« Reply #35 on: June 21, 2017 - 02:44:37 pm »
Did that fix it for you?
That's what I've been hearing from people. Milondon makes the Tstat that's in there...they seem to have a pretty good reputation. I'll start there...there is just no reason why the motor should be that hot, when the radiator is at 140....water must not be getting circulated somehow.
The one thing I'm worried about is that I had a shop flush it about a year ago when it was running hot, and they said a TON of goop came out. When this radiator went in nothing came out that wasn't green coolant. Would pulling the back freeze plugs reveal build up, as I believe that is the lowest point in the motor.
Offline cudabob496
« Reply #36 on: June 21, 2017 - 03:32:19 pm »
may want to put in a flushing chemical once, and running engine,
before doing water pump replacement, to see what get out?
« Reply #37 on: June 21, 2017 - 05:54:37 pm »
I would agree. Good idea.
Offline cudabob496
« Reply #38 on: June 21, 2017 - 06:24:08 pm »
and to get all old coolant out, there is a block drain on each side of block, above
oil pan.  Before putting in new Thermostat in, drill a small 1/8 inch hole in it, so that when filling
engine, air will not be trapped below Tstat.
Offline cudabob496
« Reply #39 on: June 21, 2017 - 06:28:57 pm »
assume you have a quality lower hose that is not collapsing when driving?
Offline cudabob496
« Reply #40 on: June 21, 2017 - 06:41:24 pm »
keep flushing till water clean. But of course, you
have to keep an eye on engine temp.
Offline 734406pk
  • Andy
« Reply #41 on: June 21, 2017 - 10:53:18 pm »
One easy way to vent air from the cooling system is to drill a small hole (1/16"+ -) through the flat area on the thermostat. This will allow small air bubbles to bypass the thermostat while it is closed. Some thermostats incorporate this air bleed feature in design, labeled as a "jiggle wire" type, which closes the bleeder at high flow.
Since you already have an IR heat gun, i would check the temp at the top of the radiator, right at the location of the upper hose location and compare the temp reading at the same area near the lower hose. This temp differential will determine your radiator/fan efficiency in heat rejection. Test this when you are at op temp or a little above. Work safe!
Offline cudabob496
« Reply #42 on: June 22, 2017 - 01:58:22 am »
Impellar may be just spinning loosely on pump shaft,
as if a key came out or something. Have read that actual
coolant temp in head is about 15 degrees hotter than water
going to the radiator.
« Reply #43 on: June 22, 2017 - 10:05:49 am »
This stuff works.
Offline cudabob496
« Reply #44 on: June 22, 2017 - 02:52:51 pm »
ya, there's a way to fill system, then run engine without rad cap,
until all the air bubbles out
