Author Topic: 440+ 6 Temperature spike when stopped...even for a short time.  (Read 3366 times)
Offline 734406pk
  • Andy
Re: 440+ 6 Temperature spike when stopped...even for a short time.
« Reply #15 on: June 20, 2017 - 10:16:40 pm »
Does the thermo clutch seem to be engaging at high temp?
Offline cudabob496
Offline cudabob496
« Reply #17 on: June 20, 2017 - 10:19:00 pm »
if around 200 degrees, that's fine.
also, I use this, two bottles.
https://www.summitracing.com/parts/rpo-01600
get better cooling if use 80% water, 20% antifreeze.  The purple ice has corrosion inhibitors.
Also should put a zinc in your water pump housing.
Offline Travis Blake
« Reply #18 on: June 20, 2017 - 10:42:45 pm »
I've heard that from a lot of people about the 200 mark. I'd be fine if it would stop there. but it has no trouble going to 215+, at which point it stalls as soon as I pull it into gear, reverse or first. I'm assuming it's vapor locking at that point. My first step is to try to richen it up a bit. I just need to find a photo of where that screw is.
1974 Dodge Challenger  - 440 Six Pack
2015 Jeep Wrangler Unlimited - Willy's Edition
Offline cudabob496
« Reply #19 on: June 20, 2017 - 11:13:05 pm »
this may be a no brainer. If idle is low, then water pump is moving too slowly.
Also, is it a quality water pump. Also, at low idle, fan moves slowly. So up the idle
some and see what happens. I have my car idling at 1400. I slip it into neutral
at stop lights. Also, bottom rad hose is to be bigger than upper hose.
« Last Edit: June 20, 2017 - 11:15:04 pm by cudabob496 »
Offline jhaag
« Reply #20 on: June 20, 2017 - 11:17:20 pm »
Quote
OK good to know. I just looked and I don't see anything in the baseplate....is it the screw below the 3 in the picture attached by chance? If not, any chance you can add a photo, or point me to one online?
Yes that is the idle mixture screw. You must have aftermarket carbs. More than likely will not fix your heating issue anyway. If I understand you correctly the radiator temp is 140 and stays there, but the car still heats up? If that is the case you are not moving enough water through the engine. Either wrong pulleys, restriction of some kind, or possibly too much clearance between the water pump and housing.  :2cents:
love 70 Challengers
« Reply #21 on: June 20, 2017 - 11:24:12 pm »
Roger that. Yep, they're aftermarket carbs. I'm just going for lowest hanging fruit first just to see. Yes, that is correct. the radiator stays at 140, but the block is heating up. I'm inclined to agree with you about not moving water, I'm just confused about what is causing it. This is the pulley I've got: http://store.440source.com/Water-Pump-Pulley-Non-A_C-New-Reproduction/productinfo/132-1002/
Should I look for a different one? here are a couple pics of the pulley:
« Last Edit: June 20, 2017 - 11:47:48 pm by Travis Blake »
Offline cudabob496
« Reply #22 on: June 21, 2017 - 12:18:26 am »
I think water pump impellers can be installed backward?
Or at least I think I read that once?
« Last Edit: June 21, 2017 - 12:20:48 am by cudabob496 »
Offline cudabob496
Offline tman
« Reply #24 on: June 21, 2017 - 02:04:42 am »
Air bubble in system or Tstat is not opening.  I know you said its new, but...........
Offline onebadfish
« Reply #25 on: June 21, 2017 - 02:25:15 am »
Sounds to me like a water circulation problem at idle.
Offline 73440
« Reply #26 on: June 21, 2017 - 05:39:20 am »
Check thermostat install direction and test thermostat as mentioned for proper temp opening.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 389,060 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #27 on: June 21, 2017 - 06:03:01 am »
Yep, stat is installed and working correctly. Its done this with 3 separate stats.
Could the water pump housing have anything to do with this?? It's a cast iron housing, not original to the motor.  I think I got this on EBay. But it is in fact a Chrysler BB. housing.
« Last Edit: June 21, 2017 - 06:04:41 am by Travis Blake »
« Reply #28 on: June 21, 2017 - 08:04:26 am »
It's not the stat, I can say with certainty. I've installed three different one ranging from 160 to 180 to 195 just to make sure. If it is in fact an air bubble  is there a way to purge that?
« Reply #29 on: June 21, 2017 - 08:42:34 am »
One other thing I just noticed this morning is that the top hose is "pliable" when squeezed when the engine is hot. In the past, when you squeeze it, it felt pressurized, which I was always under the impression is correct. Could the pliability be a sign of air in the system?   If so, how do I purge it?
« Last Edit: June 21, 2017 - 08:45:01 am by Travis Blake »
