Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Door Alignment
« previous
next »
Print
Pages: [
1
Author
Topic: Door Alignment (Read 809 times)
EMCD
Full Member
Door Alignment
on:
February 10, 2017 - 10:02:19 AM »
My DS door seems off. it sits high and its has a gap on the bottom of the door and the gap gets larger as you go from the top down to the bottom on the back side. Any tips on easy door alignment?
Logged
67vertman
Sr. Resident
Member since 9-23-2005
Re: Door Alignment
Reply #1 on:
February 10, 2017 - 11:10:16 AM »
There is no (really) easy way to do it. the door is heavy so having some support under it helps. after that it is trail and error. loosen the bolts just enough to let the hinges move. Sense it high you need to bring the bottom hinge in...towards the fender.
Logged
Current ride - 1970 Barracuda 440-6 4 sp Dana 60 (4:10)
EMCD
Full Member
Re: Door Alignment
Reply #2 on:
February 10, 2017 - 11:50:45 AM »
ok, i'll use one of my jacks to support the door. loosen the nuts on the door? or the jam? also, I'm sure when I get it right/better, i'll need to realign the door latch and knob. can you think of anything else I should consider?
Logged
rUNCHARGER
Sr. Member
Re: Door Alignment
Reply #3 on:
February 10, 2017 - 12:04:03 PM »
First thing to check is if the hinge pins are worn out. Open the door and then see if you can lift the back of it. If you can pick up the back of the door the pins/holes in the hinges are worn out and you will have to deal with that before adjusting anything.
Sheldon
Logged
EMCD
Full Member
Re: Door Alignment
Reply #4 on:
February 10, 2017 - 12:20:05 PM »
I re-sleeved the hinges when I restored the car. so, they're good.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Door Alignment
