Author Topic: TRICK FLOW 240 VS EDDY RPM  (Read 740 times)
Offline CUDA8U
« on: April 18, 2017 - 06:49:20 pm »
EDDY RPM FLOW: 291 IN 217 EXH
TRICK FLOW 240: 325 IN 257 EXH
Has anyone went from rpm to TF? What were the results?
Offline 734406pk
  • Andy
« Last Edit: April 18, 2017 - 08:33:38 pm by 734406pk »
Offline cudabob496
Re: TRICK FLOW 240 VS EDDY RPM
« Reply #2 on: April 18, 2017 - 08:39:02 pm »
The TF have pretty amazing flow numbers, for the money!
Offline CUDA8U
« Reply #3 on: April 18, 2017 - 09:22:26 pm »
FYI there is a Trickflow Powerport 270 as well now.  CNC'd Max Wedge intake ports! :woohoo:
https://www.summitracing.com/parts/tfs-61617801-c01/overview/
https://static.summitracing.com/global/images/chartsguides/t/tfs-61617801-c01_wj.pdf
https://static.summitracing.com/global/images/chartsguides/t/tfs-61617801-c01.pdf
will I need special offset rockers etc for the 270's?
I am running rpm's and think there's a lot of room to move up in hp/tq
Offline CUDA8U
« Reply #4 on: April 18, 2017 - 09:39:32 pm »
I am currently running an engine I bought off of a MOPARTS member and don';t have all specs.
This is what I know:
-512 440source 5060                                     http://www.440source.com/pistonmastertable.htm
-rpm heads
-440source 1.6 aluminum roller tip rockers 200-1046,.650 rocker spacers
-ch-28 dual quad eddy 600's
-hughes heh3237bl cam                               http://www.hughesengines.com/TechArticles/hehseriescamprofilesbigblock.php
-2800 stall,8-3/4 3:55
I feel like there's much more potential here and am considering: trick flows,single carb/intake,bigger cam,or possibly port/polish my rpm's
 I'm looking for a budget hp/tq upgrade,feel free to comment. thanks Wayne
Offline 734406pk
  • Andy
« Reply #5 on: April 18, 2017 - 11:00:33 pm »
Quote: will I need special offset rockers etc for the 270's?
Looking at the pic of the top of casting, i would say no. The intake port casting has already been redesigned to eliminate the "dogleg" inside the port.
-rpm heads
The build looks good, I think the Trickflow heads would be an improvement. Plenty of cam for the street IMO. I would get rid of the dual plane/dual quad and go with a single plane manifold and a Holley Ultra XP carb or similar. Maybe upgrade the rocker arms.
Offline CUDA8U
« Reply #6 on: April 19, 2017 - 01:15:50 am »
-rpm heads
 The rocker arms worry me for sure.I'm not sure if porting these rpms will get the same flow numbers etc. I like the look of the ch-28 but hate eddy carbs! I think the intake/carbs are robbing me of 50 hp and are sh!tty to tune.Right now with my air cleaner "the lowest I could find locally" only allows me a 3/8" spacer or it will hit the hood. I wonder what a good selling price would be for the intake/carbs/linkage/fuel inlet line/rockers.air cleaner and heads?Maybe 5000 miles on them.
Offline 734406pk
  • Andy
« Reply #7 on: April 19, 2017 - 08:58:00 pm »
Porting the Eddys may work but the cost is high. Also they don't have superior (IMO) CNC heart shaped combustion chambers. The CH-28 does look good but doesn't do much for h.p. improvement IMO. A correct single plane intake with a 950 cfm Holley type carburetor would work much better. I sell good used parts for 1/2 of the price as new. Seems to work, everybody is happy! Good luck!!
« Reply #8 on: April 21, 2017 - 03:17:30 pm »
no contst here Eddy = junk
 Trick Flow =superior in every way
