Author Topic: New camshaft  (Read 1618 times)
Offline jimynick
Re: New camshaft
« Reply #15 on: April 19, 2017 - 11:17:46 pm »
Everybody mentions the fuel system, but the cooling system is nearly as important and you'd want to make sure the hoses are on good and tight, fan belts tight and coolant levels where they should be, shrouds installed, etc. because the idea is to run it at highway rpm for 20 minutes and it's going to get hot and need to be cooled properly.  :cheers:
Offline 73440
Re: New camshaft
« Reply #16 on: April 20, 2017 - 02:57:29 am »
A fan to assist with airflow thru the radiator, water hose handy.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 394,137 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline xtopfuel
Re: New camshaft
« Reply #17 on: April 20, 2017 - 06:03:34 am »
very good points
Offline Grec
Re: New camshaft
« Reply #18 on: April 20, 2017 - 10:44:46 am »
I had my 440 Six-Pack rebuild last year with that exact Lunati Voodoo cam. The things an absolute beast now. You're gonna love it! Good times.  :thumbsup:
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline 734406pk
  • Andy
Re: New camshaft
« Reply #19 on: April 20, 2017 - 10:00:49 pm »
https://pisuladevelopmentcompany.box.com/s/ydzun219r340mmqgijgcba6wlb1iwsjx
https://pisuladevelopmentcompany.box.com/s/l19przhqo1bq6xbe4y1nps63ud73oxya
Info from Hughes Engines and Crane on camshaft install and break in.
Now this is some good info from Hughes Engines! Reduces the chance of cam damage during break in. Thanks for posting!  :2thumbs:
Re: New camshaft
« Reply #20 on: April 21, 2017 - 02:48:05 pm »
:2thumbs:
But one article said to remove the inner springs. So far, I have not seen where Lunati said to remove the inner springs. I have the matching Lunati springs with this cam and they have an inner and outer spring. Do I need to buy an 'on the engine' valve spring removal tool and take out the inner springs for initial fire up? :clueless:
Re: New camshaft
« Reply #21 on: April 21, 2017 - 03:19:10 pm »
do you need a dual sprig or just a good single or Beehive type
Offline Strawdawg
    • Vortex Buicks
Re: New camshaft
« Reply #22 on: April 21, 2017 - 08:55:40 pm »
Lunati knows what they are doing with their cams.  :)   This cam does not have excessively strong springs and it will be fine to break it in with both installed.
Offline Aussie Challenger
Re: New camshaft
« Reply #23 on: April 21, 2017 - 10:45:46 pm »
Having weak springs in for the break-in is an advantage, places less load on the cam and lifters, once everything has normalized then the correct springs can then be installed. It might be extra work but today especially with the oils not having Zinc in the formula everything counts, some even leave the weaker springs in for the first 500 miles or so.
Re: New camshaft
« Reply #24 on: April 22, 2017 - 07:10:29 am »
After I picked up the cam (703) you and others recommended, I checked with Lunati for springs. Tech guy came back saying to buy the 73100K2 valve spring kit...So I bought it. 333lb spring rate.
Re: New camshaft
« Reply #25 on: April 22, 2017 - 08:13:44 am »
Here's some break in oil that I have used successfully.
https://www.summitracing.com/parts/jgr-03706/overview/
Thanks for the reminder. I have high zinc synthetic in there now. Everything I read says use break-in oil, no synthetics.
Offline 734406pk
  • Andy
Re: New camshaft
« Reply #26 on: April 22, 2017 - 10:11:58 pm »
Here's the Lunati brand of oil additive for cam break-in. It's required for warranty for Lunati flat tappet cams.
https://www.summitracing.com/parts/lun-301
Offline xtopfuel
Re: New camshaft
« Reply #27 on: April 23, 2017 - 08:26:33 pm »
No synthetic and no you don't need to remove inner spring
Offline Strawdawg
    • Vortex Buicks
Re: New camshaft
« Reply #28 on: April 24, 2017 - 10:22:15 am »
These are not extremely high pressure racing springs.  There is no need to remove the inner spring.  As I said before, Lunati does have some experience in this field so let's not confuse the type of cams/springs that the magazines discuss with street cams.
Personally, I prefer running a commercially packaged break in oil since they are available these days but using the additive works very well today as it has for the last 50 years.  Personally, the main reason that I don't like using synthetic oil during break in is that it's going to get drained and replaced shortly after break in and it's a lot of money down the drain.
In the end, take the cam manufacturers suggestions and follow them in this field.
Re: New camshaft
« Reply #29 on: April 24, 2017 - 12:34:06 pm »
I bought break-in oil, so the additive is not req'd?
Thanks everybody for the abundance of advise. It is appreciated!  :cheers:
Unfortunately, work has me scheduled to work for the next three weeks straight with major O/T - 12-16hrs a day. So I won't be able to do this job until mid May! But I'll have more $ for parts!
