Cuda-Challenger.com
Chryco's Tech Shop => Electrical => Topic started by: 340-FOUR- BARRELL on April 20, 2017 - 11:04:47 PM
Title: 73 Challg gauges don't work
Post by: 340-FOUR- BARRELL on April 20, 2017 - 11:04:47 PM
Bought a 73 Challenger last week. The head lamps, tail lights, horn, dome light, speedometer all work. The oil pressure gauge, water temp, ammeter, fuel gauge, tach, wipers, turn signals, don't work. The seller said the dash voltage regulator may need replacing. Where is the dash voltage regulator located? There are some electric connectors/plugs that are not being used under the dash...could this be the problem? Near left side of glove box (six spade connector), and next to steering column three plug connector not being used. Any suggestions, Thank You
Title: Re: 73 Challg gauges don't work
Post by: Lbs on April 20, 2017 - 11:24:03 PM
The voltage limiter is on the backside of the gauges. Not sure if that's the problem but it makes sense. Somebody here will shed some light on it for you. (https://uploads.tapatalk-cdn.com/20170421/384be2b426dbe2ea82eafcf6fc9ed8d6.jpg)
Post by: Beekeeper on April 20, 2017 - 11:53:06 PM
Don't ignore the possibility that there are several unrelated problems occurring at the same time. Since you just got the car, some of these things could have failed over time separately. If you're lucky, a simple fix will cure everything.
I'd start by verifying that all ground wires in and around the dash and engine compartment are properly connected.
I'm thinking gauges are all one problem. You can see from lbs's pic that the gauges which are not working are all fed from the same source so maybe that voltage regulator or that wire cluster is the issue on the gauges.
I'm wondering if your turn signals are something else. You said tail lights work but you didn't say if brake lights work. The turn signals use the same element as the brake light so if brake lights work, you can narrow that down to the column or dash wiring. I would think your turn signals would normally work even if you removed the gauge cluster. Check the wiring looms coming out of the column...people cut and splice and disconnect those all the time.
It's not unusual for the tach to fail over time. Could also be that the feed wire for the tach on the coil is not connected properly.
On the wipers, possible a switch went bad or the wiper motor failed.
Did the seller say if all these things failed on the same day or one by one. I'm gonna guess one by one.
Post by: Lbs on April 21, 2017 - 12:37:40 AM
I see from your other post that you are in the Bay Area which is where I am also. I'm in Pacheco which between Martinez and pleasant hill. If you would like some help with it you can PM me or their is a cruise night tomorrow at Kinders in Concord off highway 4. Mopar Jack might be there and he is a pretty sharp guy and usually willing to help.
Post by: 340-FOUR- BARRELL on April 21, 2017 - 03:12:39 AM
Beekeeper the driver side brake light works when the brakes are applied. Passenger side brake light does not come on. Hmmmm I will check all the ground connection, tach to coil wire, and the voltage limiter on the back side of the gauges.
Lbs, I will try to make Kinder's in Concord this Friday nite. When is a good time to be there?
Post by: xtopfuel on April 21, 2017 - 06:41:57 AM
LOL I am having same issues
Post by: Beekeeper on April 21, 2017 - 09:39:25 AM
I am no expert when it comes to electrical issues but it's been my experience that older cars like ours deteriorate fast and require tons of maintenance which many owners don't have time for. Hopefully someone will chime in with a simple solution but I think you're gonna have tackle them one by one. I'd pick the thing that bothers you most...for me it would be the gauges. A pain yes but I'm certain that the failure of the three gauges is due to one cause so if you track it down, you should be able to fix three of them all at once.
Post by: mopar jack on April 21, 2017 - 10:00:11 AM
The cruise night gathering starts around 5:00  and ends around 7:00. Hope to see you there.
Post by: chargerdon on April 21, 2017 - 02:20:30 PM
Just my two cents...   The voltage regulator only controls the gas, temp and oil pressure.   The amp meter is NOT part of the voltage regulator.   A lot of guys disconnect the amp meter for fear of melting or catching on fire.
Gauges have noting to do with the brake lights.
So, you do have multiple issues.
