Author Topic: 71 340 dip stick issue  (Read 712 times)
Offline citron fella
« on: July 11, 2017 - 07:52:23 pm »
it's difficult to reinstall the dip stick in my 71 340. is this normal?
1971 Dodge Challenger #matching 340 citron yella
Offline Rich G
Re: 71 340 dip stick issue
« Reply #1 on: July 11, 2017 - 08:03:24 pm »
No. It should be a straight shot down.
« Reply #2 on: July 11, 2017 - 08:34:57 pm »
does your dip stick read "this side up when checking oil" on one side?
Offline burdar
« Reply #3 on: July 12, 2017 - 11:26:42 am »
Pictures are worth a thousand words.  Do you have the correct dipstick?
« Reply #4 on: July 12, 2017 - 12:15:58 pm »
the dip stick is difficult to reinstall two hands are needed i don't remember checking the oil on my dad's challenger being this difficult
Offline burdar
« Reply #5 on: July 12, 2017 - 12:20:44 pm »
Your dipstick tube is severely bent.  It should be a straight shot from the top all the way down until it goes into the block.  The tube shouldn't have that big bend in it at the top.  Once you replace the tube, the dipstick itself will point front to back...not side to side.
Offline burdar
« Reply #7 on: July 12, 2017 - 01:01:58 pm »
thanks burdar, do you have a working link i can purchase from?  i'm bummed :(
Offline burdar
« Reply #8 on: July 12, 2017 - 01:07:58 pm »
I just googled SB Mopar dipstick.  I think that picture was from Classic Industries.  Not sure how expensive it is.  I'm sure you can find that tube in a lot of places.  Check Roseville and Mancini Racing.
« Reply #9 on: July 12, 2017 - 03:39:07 pm »
i'll look at things tomorrow maybe i can remove the ds and bend it back
Offline burdar
« Reply #10 on: July 12, 2017 - 04:57:03 pm »
Just by the looks of your picture, my guess is that the bottom is bent as well.  I think you'll find that tube is pretty much a pretzel.
What I think happened was that the bottom of the tube was bent and someone had to bend the top to clear the alternator spacer.  The tubes are kind of thin.  Be careful so you don't break off the end inside the block.
« Reply #11 on: July 12, 2017 - 05:38:30 pm »
copy that i'd remove it from the block before i crank on her. i almost bought a replacement from a mopar distributor but the shipping at checkout was bananas. i'm guessing the mr. gasket tubes are junk cause that's what mine looks like. the bend in my tube looks un damaged all the way to the block. it's very similar to what's currently on eBay :(
Offline 73440
« Reply #12 on: July 12, 2017 - 11:16:15 pm »
Yah, I snapped mine at the block when pushing against it when replacing the motor mount, currently have a hose clamp holding it together,
One day will put the replacement tube thats bought in.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 392,692 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline burdar
« Reply #13 on: July 12, 2017 - 11:25:25 pm »
I did it too. Then I tried drilling out the stuck piece and slightly over sized the block hole. I ended up having to expand the end of the replacement tube so it would be tight.
