Author Topic: Doug's Headers sitting to low. What about TTI?  (Read 2287 times)
Offline daryld
« on: May 18, 2017 - 07:05:44 pm »
Guys,
I am trying to avoid having to pay for custom built headers if possible. Every quote I got was around $2k. The Doug's I have only a few inches of ground clearance and I am wondering if any of you big block guys have better clearance with TTI or other brands? I have a Magnumforce K-frame so I cannot use the Tri-Y system or shorties because they will not clear, not even with a mini starter. I am looking for headers that will stay high and will allow my exhaust to hug the floor. If I cannot pick up another 2-3 inches than they are not worth changing.
Thanks for all your help.
Daryl
Daryl
Offline Cudakiller70
Re: Doug's Headers sitting to low. What about TTI?
« Reply #1 on: May 18, 2017 - 09:17:05 pm »
just throwing it out there what about stock HP extruded? :dunno:
The above is just my opinion
John Adams
Offline daryld
« Reply #2 on: May 18, 2017 - 09:48:24 pm »
I appreciate the reply but that would not fit the look of the car. Like the imagination though.
Daryl
Offline jason340
« Reply #3 on: May 19, 2017 - 09:29:22 am »
70 Challenger 440 TTI headers. 4" from the collector flange to the ground with a 24 1/8" ride height at the center of the front fender wheel well. I hope this helps.
Offline daryld
« Reply #4 on: May 19, 2017 - 11:05:30 am »
Certinely does. I believe TTI ground clearance has got to be better than what I have. Thanks!
Daryl
Offline burdar
« Reply #5 on: May 19, 2017 - 04:55:43 pm »
I'd research around some more. I think the Dougs small block headers are basically the same as TTI small block headers. The big block headers might be the same situation.
Maybe there is someone who can modify the ones you already have. Probably not cheap but should be less expensive than a brand new custom set.
Offline Katfish
  • 70 Challenger
« Reply #6 on: May 19, 2017 - 08:12:16 pm »
Any long tube header will hang down in that area.
I'd be thinking about some shorties if stock manifolds are a no go.
Offline daryld
« Reply #7 on: May 20, 2017 - 10:33:09 am »
I have considered shorties but Ken at Magnumforce told me that they were never able to make them work with his k-frame. So this rules out shorties. I looked at a Tri-Y set up but they do not work with my TKO, only auto or 4 speed. Hedman has a set of protouring mid length headers. I just sent them an email to see if they will work with my suspension. Let you guys know what they say. I just do not know how people with low ride height e bodies use long tube headers. Thanks for all your input.
Daryl
Daryl
Offline daryld
« Reply #8 on: May 20, 2017 - 10:36:00 am »
Which set of TTI are you running? I see a few options on their site. The 2 1/8 low deck step headers claim to give the maximum amount of ground clearance.
Daryl
Offline jason340
« Reply #9 on: May 21, 2017 - 09:23:28 am »
They are the TTI440-200c  2" primaries ,3 1/2 collectors long tube.
David
Offline daryld
« Reply #10 on: May 21, 2017 - 05:37:47 pm »
Do you guys know how much adjustment there might be in the motor mounts? It does not appear that there is much difference between the Doug's and TTI full length headers, so I am not sure if swapping will gain me much ground clearance. Shorties may offer me more clearance but I apparently sacrifice noticeable hp and torque. I am wondering if raising the motor and changing the pinion angle can get me two inches. My exhaust is no where near the floor boards so I am wondering if making some adjustments may give me more ground clearance.
Please share your opinions. Thanks again for all the input.
Daryl
Daryl
Offline 73_Cuda_4_Me
« Reply #11 on: May 21, 2017 - 06:08:13 pm »
Your biggest gain would be by raising the back of the transmission, but you probably do not have much to work with there... it changes the angle of the header pipes, tucking them closer to the floorboards...
You could get almost a .75:1 or .8:1 gain with regular length headers, depending on where collectors are in relation to the tranny mount...
R11 V6X EN2
M21 M25 M31 M88 N41 N42
V1X U B41 C56 G37 J54
JY9 A6X9 0 703 501616
E55 D34 BS23 H3B 567783
Offline burdar
« Reply #12 on: May 21, 2017 - 09:53:44 pm »
That's why I suggested having your existing headers modified. Basically make each header two pieces. Turn them into a big slip tube. Cut the headers in half somewhere in the middle. Expand the tubes on one half so you can slide the other half of the header tubes together. This would raise the collector closer to the floor. Not easy or cheap but would probably be cheaper then custom.
Offline Racer57
« Reply #13 on: May 21, 2017 - 10:17:17 pm »
If header tubes were perfectly parallel to each other, that might be possible.
Offline xtopfuel
« Reply #14 on: May 22, 2017 - 06:04:38 am »
this is a great subject, I would think someone has purchased a set that fit well, I was considering the Dougs until I saw this thread because the ones I have currently the pitman arm hits and doesn't allow a full left turn, also low ground clearance
