Author Topic: Doug's Headers sitting to low. What about TTI?  (Read 2535 times)
Offline xtopfuel
Re: Doug's Headers sitting to low. What about TTI?
« Reply #15 on: May 22, 2017 - 06:09:17 am »
I will have to try a set, hard to make a uturn as is lol
Offline GoodysGotaCuda
« Reply #16 on: May 22, 2017 - 10:33:17 am »
If header tubes were perfectly parallel to each other, that might be possible.
And they probably aren't.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #17 on: May 22, 2017 - 11:11:00 am »
I was just describing the basic idea.  It's obviously going to be more complicated then that.
Offline 1 Wild R/T
« Reply #18 on: May 22, 2017 - 04:10:02 pm »
So what does Ken at Magnumforce say will fit properly & tuck in nicely?  Seems odd that they haven't done the research for their customers.....   :2cents:
Offline daryld
« Reply #19 on: May 22, 2017 - 05:14:39 pm »
Ken recommends TTI and also sells the product.
Daryl
« Reply #20 on: June 05, 2017 - 06:44:13 pm »
I would start with a measurement from the header flange to the bottom of the pipe ,maybe the whole engine is sitting low causing the problem
Offline shawge
  • Zoiks!!
« Reply #21 on: June 05, 2017 - 06:59:08 pm »
Do what Chryco says and take some measurements.
You got a TKO?  I think that is what I spy in your pics.
What is your engine/trans angle? I've got a TKO, BB,  and have 5 degrees down - my Dougs headers looks like yours. I plan to raise up the transmission like 73_Cuda_4_Me mentions. Shooting for 3 degrees - about 1" in spacers.  Raising the trans with a jack just 1/2" tucks in the headers nicely,
- Jerry
Offline daryld
« Reply #22 on: June 05, 2017 - 10:52:54 pm »
No idea what the angle is but that is exactly what I am planning. I bought the car as is. I measure 1-1.5 inches of clearance between the trans and tunnel so I know there is room. I am also going to check the motor mounts to see if there is anything there. Because I recently had a 4-link installed I will have some room to adjust there too. If I can pick up another 1-2 inches I will be very happy. I will keep you posted and remember to send you the angle when done.
Daryl
Offline shawge
  • Zoiks!!
« Reply #23 on: June 06, 2017 - 03:47:36 pm »
You won't get much from the mounts. Biggest gain will be  from the trans mount.
- Jerry
Offline daryld
« Reply #24 on: June 06, 2017 - 04:15:57 pm »
May not matter because I am seriously thinking about swapping the motor for a 6.4 392 Gen 3. Then I will be back to the drawing board with mounts and pinion angle but should get more clearance with small block headers anyway, I think. If I do make this switch I will be putting my Mopar Performance 440/6 pack up for sale. Motor will be turn key w the Doug's headers and March belt drive system. Will keep you all posted.
Daryl
Offline PLUM72
« Reply #25 on: June 27, 2017 - 05:19:56 pm »
Small Block?  What about a set of '92 to '02 Dodge Dakota headers?  They have a swept back design that keeps things high.
Offline daryld
« Reply #26 on: June 27, 2017 - 09:36:19 pm »
Big block.
Daryl
Offline 340-FOUR- BARRELL
« Reply #27 on: June 27, 2017 - 10:32:07 pm »
A plausible alternative is side pipes.
Offline shawge
  • Zoiks!!
« Reply #28 on: August 29, 2017 - 02:18:49 pm »
Still need to being the end of the TKO trans up otherwise the drive line angles would be set up for binding and vibrations.
- Jerry
Offline ragtopdodge
« Reply #29 on: February 13, 2018 - 08:30:02 pm »
Surprised Schumacher TRI-Y's don't fit.
Won't work w/a TKO?  Pfft.  C'mon.   Use a hydraulic TO bearing.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
