Author Topic: 340 engine mounts...  (Read 1153 times)
Offline culp71
« on: June 24, 2016 - 11:25:03 am »
second guessing my self as engine was blank when I got it,
which side should the engine mount brackets be bolted to the engine,
and which direction should the bolts/nuts be?
Offline CUDA JAS
  • vroooooom!
Re: 340 engine mounts...
« Reply #1 on: June 24, 2016 - 11:37:00 am »
The mounts should be behind the ears on the block.
The bolts I am not sure about.
Jason
74 'cuda 360/727
Just call me a gearhead!
Offline burdar
« Reply #2 on: June 24, 2016 - 12:54:05 pm »
The nuts were on the front side on mine.  My guess is that it could have varied.
Offline anlauto
« Reply #3 on: June 24, 2016 - 05:07:32 pm »
Everything goes in from the rear :naughty:
Offline AU6pack
« Reply #4 on: June 19, 2017 - 01:35:21 am »
I got me engine back from the shop and today and i have a 340 mount problem.
I removed these mounts off a 340 block and I built a MP 340 new block. Everything is supposed to bolt straight back on.
The passenger side bolts up just ine. The drivers side is no 1/2 out and doesn't look like it will mount up, not with out some large shims.
Can anyone shed some light on why its different and what to do? Are there more than one mount for a 340 block?
Thanks
Craig
Melbourne, Australia
1970 Challenger 416 6 pak
Resto thread - http://www.cuda-challenger.com/cc/index.php?topic=114787.0
Offline burdar
« Reply #5 on: June 19, 2017 - 12:11:14 pm »
I believe I read once that the MP 340 blocks have the 318 motor mount flanges.  Don't know why they did it that way.
Offline AU6pack
« Reply #6 on: June 19, 2017 - 06:51:49 pm »
Thanks Burdar. Should be OK with a shim then i hope.
Craig
Offline burdar
« Reply #7 on: June 19, 2017 - 07:14:53 pm »
Yes, you can shim it. Use a bunch of washers or machine a spacer for a cleaner look.
EDIT:  You can shim a 318 mount to fit a 340/360.  However, you can't shim a 340/360 mount to fit a 318.  Sorry for the incorrect info.
« Last Edit: June 24, 2017 - 10:42:04 pm by burdar »
Offline AU6pack
« Reply #8 on: June 23, 2017 - 07:11:40 pm »
That is correct. In case anyone is in my position, the replacement Mopar Performance block - MP 340, or 340 M uses a 318 mount on the driver side. All standard on passenger side.
Why? Who knows, but Schumacher Creative Services can help you out.
Craig
