Author Topic: Misc Electrical questions,,,,  (Read 689 times)
Offline 69CHARGERMD
« on: October 14, 2017 - 09:43:46 pm »
Car is almost done,,,motor and trans in,,,running,,
I wired up a MSD 6AL,,plumbed some aftermarket gauges ( oil press, H2O temp, volt ), tach, etc,,,,
Questions:
1) Is there a common ground that would be good to use for the aftermarket gauges ? ( I have several gauges that need to be grounded,,,Where would be a good place to ground all of these things ? )
2) Dome light does not work,,,,(perhaps a ground issue with the door switch ?
3) Trunk light does not work,,,,,does this "active" when the trunk opens or is this run off the dash ?
4) Switch for the bright's ( front headlights ),,,doesn't work,,,
I struggle with electrical stuff,,,so forgive me for the above questions,,,,would like to fix all of this myself,,,and learn some stuff in the process....
Doug
« Last Edit: October 14, 2017 - 09:45:39 pm by 69CHARGERMD »
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline 734406pk
  • Andy
Re: Misc Electrical questions,,,,
« Reply #1 on: October 19, 2017 - 08:04:39 pm »
First ground the dash frame to the car body with few braided ground straps then ground the gauges to the dash frame. Do you have a 12 volt test light?
Offline JayBee
« Reply #2 on: October 19, 2017 - 09:37:21 pm »
3) Trunk light comes on when the trunk is open, mercury switch within the socket housing. Make sure there's a good ground where it screws to the trunk lid.
John
1970 Barracuda convertible
2000 Toyota Avalon
Offline 734406pk
  • Andy
« Reply #3 on: October 20, 2017 - 11:16:32 am »
Also do your brake lights come on when you press the brake pedal?
Offline 69CHARGERMD
« Reply #4 on: October 21, 2017 - 07:06:18 am »
Thanks guys for the replys.
1) I will get some ground straps for the dash frame,,,,i have a test light,,,,
2) Mercury switch in the trunk light ? ( do these go bad ?? ) ( i will also make sure it is grounded properly )
3) Brake lights, tail lights, headlights, running lights all work,,,( except the side marker lights on the back quarter panels ? )
Thanks for the above info,,,this gives me some things to work on
Doug ;)
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
Offline JayBee
« Reply #5 on: October 21, 2017 - 08:58:52 am »
I've had a couple of them that never went bad, but I guess anything's possible. The one in my car still works after decades of trunk slamming. Here's a picture of a glass encased one showing how they work. When tilted the mercury rolls to the contacts and completes the circuit.
John
2000 Toyota Avalon
Offline 69CHARGERMD
« Reply #6 on: October 27, 2017 - 08:00:44 pm »
Thanks Jay !! cool picture.....
1970 Challenger WSS
1969 Charger RT/SE
1965 Belvedere
