Author Topic: Coil voltage  (Read 673 times)
Offline RedKing7
Coil voltage
« on: June 03, 2017 - 06:14:27 pm »
Any one know what the voltage drop is suppose to be across the coil on a '72 340 with electronic ignition?
Re: Coil voltage
« Reply #1 on: June 03, 2017 - 09:36:53 pm »
Starting,  close to 12. Running,  about 9.
Offline RedKing7
Re: Coil voltage
« Reply #2 on: June 03, 2017 - 10:22:39 pm »
So, I have 4 with the ignition switch on.  Won't turn over.  Know the battery is weak.  Am going to charge over night.  Could this be a voltage regulator problem or something else?
Re: Coil voltage
« Reply #3 on: June 04, 2017 - 09:01:00 am »
Regulator can only be an issue after starting.
Low voltage with the ign sw on its likely just battery.
Offline RedKing7
Re: Coil voltage
« Reply #4 on: June 04, 2017 - 06:24:31 pm »
Thanks Scott.  I think you are right.  Battery is 2 years old, but won't hold a charge.  Will try and replace this week.
Offline RedKing7
Re: Coil voltage
« Reply #5 on: June 08, 2017 - 10:25:19 pm »
Old battery had no amps.  New battery has plenty, but still won't spark.  Have 5 volts across coil (< 1 year old).  Have 12 volts across ballast resister and coil.  No spark when pull coil wire off of distributor.  Could this be bad resister?  It is the original.
Offline mopar70maniac
Re: Coil voltage
« Reply #6 on: October 11, 2017 - 03:27:04 pm »
hello red king, was wondering what became of your ignition issue? did you get it figured out? seems a common problem as I too have similar issues. thinkin about converting to points distributor
