Author Topic: 1965 DartCharger Factory Special 273 4 spd 480 DartChargers built  (Read 719 times)
Offline pimpbot5000
I have the oppertunty to buy a DartCharger, I can't find much information on them and they're not in the Nada bluebook
Alaskan_TA
Re: 1965 DartCharger Factory Special 273 4 spd 480 DartChargers built
« Reply #1 on: March 24, 2010 - 08:49:25 PM »
Check http://www.forabodiesonly.com/mopar/ there have been a couple threads on them in the past. I do not remember values being discussed though.
Offline pimpbot5000
« Reply #2 on: March 24, 2010 - 08:57:15 PM »
1 of 480 made, 1 of 300 that were completed at the dealer .
This one was completed by dealer in LA. So fender tags show at Dart GT.
This is a Dodge Dart GT Body with Charger elements (it has all of them) that were being market tested for desirability. It is referred to as a:
DartCharger kit car or a DartCharger, ordered with no badges.
Yes, numbers match. has the Charger air filter, alum valve covers, 10" drum brakes, etc No AC
Upgrades done to make it a reliable daily driver:
Alum. racing radiator
Mopar Electronic ignition (Dist, module, and voltage regulator)
Dual field electric/charging system - Powermaster Alt
7 blade fan w/clutch
battery in truck over rear wheels w/ Summit Racing kill switch
rear sway bar
new tires
has rust through on drivers rear fender, and I have the replacement stampings.
article about one http://www.moparmusclemagazine.com/featuredvehicles/mopp_0106_1965_dodge_dart_charger_273/index.html
A restored DartCharger
http://65charger273.com/
